Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-04-2007, 10:33 PM
SrqScion is starting off with a positive reputation.
1995 f350 front spring question
I have a 95 4x4 one ton dually and i want to level it out and get the front back up. The springs are pretty much flat and not bowed in either direction. Should I buy 2" front springs or can I get away with a add a leaf? I'm new to the heavy duty 4x4s and looking to get this thing up a little bit. Any help and or expierence will help. thanks
__________________
1995 F350, 4x4, 5 speed, LUK Cluth and fly wheel, DRW, flatbed, 128k miles, 6637, coon 10k mod, 4.10's, new sticks, rebuilt turbo
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-04-2007, 11:08 PM
fordguy86 is starting off with a positive reputation.
if you plan on getting it raised up a little bit and keeping it that way, i would go ahead and get the 2 inch spring. the add-a-leaf will help, but i have had them start to sag back down after a little while.
  #3 (permalink)
Old 07-04-2007, 11:36 PM
in that case, do you have one you recommend? Not looking to break the wallet too bad but don't want junk either. Thanks in advance
__________________
  #4 (permalink)
Old 07-04-2007, 11:42 PM
try tough-country suspension or superlift.
  #5 (permalink)
Old 07-04-2007, 11:46 PM
you can call up a buddy of mine Brian. he works at Lift Kit Warehouse in Antioch, California. his number is (925) 706-2811. he can find you ANYTHING. he has helped me out big-time before.
  #6 (permalink)
Old 07-05-2007, 02:10 PM
75F350's Avatar
75F350 has a very good reputation on FTE.75F350 has a very good reputation on FTE.75F350 has a very good reputation on FTE.75F350 has a very good reputation on FTE.
Should do a shackle reversal kit www.sky-manufacturing.com this will eliminate the front swing shackle (which was a poor design) and lift the truck probably to where you want it.
  #7 (permalink)
Old 07-05-2007, 04:13 PM
i was looking at that shackle kit, actually have their rear kit on my bronco. My concern is that my springs are sagging already and would rather get new springs or add a leafs to correct that problem instead of just putting a bandaid on it. Thanks for the input though
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
