Is it even worse on an engine when it's superchargered and used for towing? A guy said that all the new trucks with supercharged engines have a 0 tow rating. Was looking to learn alil bit here.
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
__________________ Justin-FTE Moderator
95' F-150 XLT 4x4, 393ci stroker, 5 spd, 6" lift/35s
04' Explorer Limited 4.6L
94' Cobra - 1 of 123 made, only 30k miles
Off the top of my head, I remember that the new Lighnings are rated to tow up to 3000 lbs. It would stand to reason that towing puts a big load on the motor, and so does a supercharger. If it's to work, it better have some serious timing retard! Just thought I'd pass that along. TK
__________________
John F. Daly III
'77 F-100 LWB, 100% Aftermarket 302-R.I.P. (Stolen)
'95 F-150 SWB, 300 I-6 Now with 240,000 miles!
Heavy Metal - Ford Trucks - Beer - Powerlifting - Libertarian Politics MySpace Page - Add me!
Well, I do use mine to tow a 2500lbs snowmobile trailer at the most, 7-8 times a year and a 4000lbs boat once a year. I was just curious because someone mentioned it. Thanks TK.
Then theres:
99' Mustang GT 4.6L
Curtain Supercharger engines are great for towing. If you get a supercharger with a twin-screw type compressor you will receive full boost throughout the whole rpm range. Now with that being the case you will see more HP and more torque with will help you in towing. A supercharger does not put strain on the engine it actually helps it out, and that’s why under normal driving conditions you will see your gas economy increase. The main cause of premature engine wear is driving patterns like towing and racing. In many cases superchargers will help ease the strain on the engine since you engine does not have to work as hard to produce power.
Yo, TK-
I think the rating of the Harley version is also pathetic, IIRC barely rated to carry a Harley in the bed!
According to the owner's guide of my '00, the trailer tow rating of a standard F-150 5.4L auto trans is anywhere from 7,000 to 8,300 pounds, depending on tire size and axle ratio, up to 13,500 lbs GCWR.
I'd assume the drivetrain, the tranny, axle, frame, etc. of a Lightning or Harley edition is not built any weaker than a plain vanilla F-150, the reason has got to be that the engine can't reliably take running at boost for extended periods of time. Could there be any other reason?
If that's the case, then putting a blower on a truck for better towing performance is probably a bad idea. If better towing is the goal, the first thing I'd be doing is changing out the axle gearing to something appropriate for heavy towing, 3.55 and big tires just ain't going to cut it, no matter what you've got under the hood. Even the gutsy 460s and V-10s usually came with 4.10 gear sets for serious towing.
I do have 3.55s and 32" tires. Power isn't that big of a problem for towing with my 302. I just want one for more power in general, towing wasn't really my concern. The trailers i tow are pretty light. I was just curious, because I do tow, if it's a really bad thing.
Then theres:
99' Mustang GT 4.6L
if you only tow a few times a year i wouldnt sweat it too much. just retard the timing a couple of degrees before the tow. this will help with heat and detonation control.
__________________
94 lightning
ys trim vortech renegade
intercooled
detroit locker
ladder bars
42# injectors
level 10
2800 stall pi converotor
psp tuned
11.51 @ 117
501rwhp 647rwtq
STILL SPEED DENSITY
I put an Eaton M90 on the 302 in my X, and haven't had a bit of problems yet. I pull 2 jet ski's every weekend, and about once a month, I pull a 1500lb tandem axle trailer with a 6000lb John Deere tractor sitting on it. Have been doing this now for about a year. With the limited slip 3.73, it has done a very good job.
The gearing on a lightning would be high, if it needs to accelerate, which would be what you want for towing (high gears).
Then theres:
99' Mustang GT 4.6L
the gearing on the early lightnings is 4.10. and the torque rating was like 370ftlbs at 2800 rpms. more torque than any other gas engine ford made at the time, 302, 351, 460. if im not mistaken.
__________________
94 lightning
intercooled
detroit locker
ladder bars
42# injectors
level 10
psp tuned
11.51 @ 117
501rwhp 647rwtq
STILL SPEED DENSITY
He just got it backwards, very common mistake.
But for the no too mechanically inclined, a
"low" gear has a higher numerical ratio than
a "high" gear, 4.10:1 = "low", 2.73:1 = "high"
Steve & the Rockette
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'73 MG B GT 2.6L V6(Ford)
'98 Contour SVT 2.5L V6 (Mods)
'01 ZX2 (No Mods yet)
__________________
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'74 Capri 2L
Ok, a 4.10 would be quicker in acceleration and more power for towing, but a slower top speed than a 2.73 ratio. The 2.73 would be slow in all aspects, weak for towing, but you'd get good gas mileage.
Then theres:
99' Mustang GT 4.6L
