Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #16 (permalink)
Old 08-26-2002, 06:57 PM
dpoelstra is starting off with a positive reputation.
Supercharger during towing?
[updated:LAST EDITED ON 26-Aug-02 AT 06:58*PM (EST)]The low tow ratings may also be the performance suspension that is definately NOT tuned to haul a load. A light, performance and handling suspension setup will kill a tow rating regardless of the HP and tourque ratings. Just look at the tow ratings of high performance mustangs and corvettes. There nothing. The low profile tires will also reduce a tow rating.
I would love to have a supercharger on my F350 Crew cab dually's 460 to tow my 7k lb trailer!
Just a thought.
__________________
Dan
2003 F350 Super Duty Cew Cab XLT
6.0L Turbodeisel
Sponsored Links
To remove this ad, register today!
  #17 (permalink)
Old 08-26-2002, 09:14 PM
StrangeRanger is starting off with a positive reputation.
Dodge had the same problem with the Dakota R/T. They ended up buying a sh**load of them back from unhappy owners after they derated the towing and hauling capacity. Anytime you lower a truck, even if you do not soften the springs, you reduce it's towing and payload capacity.
__________________
1996 F150 XLT 2WD 4.9 E4OD.
  #18 (permalink)
Old 08-27-2002, 10:54 PM
MustangGT221's Avatar
MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.MustangGT221 has a good reputation on FTE.
I see, so the lowered ratings are because of the springs and wheel/tires. How come a lowered truck, even if the springs are the same strength, will lower the towing capacity?
Primary rig is Green Thunder:
95' F-150 XLT 4x4, 302, 5 spd, MSD 6A, Flowmaster American Thunder Exhaust, Sunroof, Clear corners w/ Diamond headlights, CD player with 2 10" subs and some 32" BFG Muds .
Check out my Gallery for a look-see.
Then theres:
99' Mustang GT 4.6L
88' F-250 Heavyduty 4x4 351/c6
95' Mercury Cougar 4.6L V-8
80' E-350 300/6 with a
3 spd column shifter. Weighs around 7,000lbs w. 65mph top speed, who wants to race me!
__________________
Justin-FTE Moderator
95' F-150 XLT 4x4, 393ci stroker, 5 spd, 6" lift/35s
04' Explorer Limited 4.6L
94' Cobra - 1 of 123 made, only 30k miles
87-96 Forum
  #19 (permalink)
Old 08-28-2002, 12:28 PM
Less clearance between the axle and the bump stops.
__________________
  #20 (permalink)
Old 08-28-2002, 04:55 PM
Well, great, thanks for the information. Glad to hear it's not harmful with towing, thanks!
Then theres:
99' Mustang GT 4.6L
__________________
87-96 Forum
  #21 (permalink)
Old 08-29-2002, 04:07 PM
gamehunter is starting off with a positive reputation.
Yes, that was me. I should have clarified a little...Vehicles like lets say a Chevro### Typhoon have a 0 tow rating. I think that is mostly due to all out sport suspention and being so low to the ground, all wheel drive, turbo, etc. I would guess super and turbos do add stress to the engine. Can't say how much for sure. But if you were to always stay below boost levels yourd be like stock, and with stock power of course. For relatively short trips I don't think it would hurt to use it on lighter loads.
__________________
'90 F-150 lariat 4x4 302 M5OD 3.55
Finally complete: 351W EFI swap (a few mods)
  #22 (permalink)
Old 08-29-2002, 09:21 PM
the law is starting off with a positive reputation.
__________________
The Law
1989 F-250 HD 4x4 460 C6
High Plains Drifter
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
