pto interchange
i know a pto is not a transfer case. i did not ask about a transfer case . please read before u try to answer. a t-18 is a h-d 4 speed trans made by borg/warner and a np 435 is a h-d 4 speed trans made new process gear/dana corp. both transmissions have a cover on the side of the case,that can be removed to install a pto. i need to know if the bolt holes on the case are the same and will the gears on the countershaft mesh ?
PTO's were only available if the truck was special ordered with one. They weren't on the options list. Very few F100/350's were fitted with a PTO. Dealers would sometimes send the vehicle out and have a PTO installed locally.
Two different transmission manufacturers, the trans cases are completely different. The NP 435 side cover is half the size of the one on a Warner T-18.
Who has a PTO service manual? The only place you might try is faxonautolit.com, or the company that built the PTO.
I am doing the reverse.I'm puting in b/w inplace of NP 435.Maybe we can help each other out.I need a PTO to fit the b/w.My np 435 has a spicer pto that worked fine.It does not fit the b/w because of the gear shaft is reversed.The pto itself bolts up to the side of the b/w but is to far away from the gear. If you are still looking or have the pto email asap this is a work in progress. esantia@***.net
hjartland
02-07-2017 12:30 PM
stanzianiman
10-15-2016 12:21 AM
hail destroyer
09-27-2016 09:36 PM
