Shifter mechanism on a 93 F-150 - Ford Truck Enthusiasts Forums
Old 07-04-2007, 11:41 AM
KCChiefs69 KCChiefs69 is offline
KCChiefs69 is starting off with a positive reputation.
This morning, I shifted the truck into Drive and the handle went all the way down to "1". I fiddled with it and it went into Reverse, Neutral and Drive but it won't go into Park. I dropped the column and found the shifter mechanism housing was broken in half. What is the technical name for that mechanism so I can search for a new one without sounding like an idiot?
Jeff
Old 07-04-2007, 11:53 AM
AH, found it.............. it's called the "Intermediate shaft".
Oops, that's the steering shaft.
Jeff
Old 07-04-2007, 06:46 PM
mhg mhg is offline
mhg is starting off with a positive reputation.
my cd for a 1996 shows the shaft name as "shift control assembly"
the two clamps that hold it down is called "gearshift lever socket and bushing"
is the shaft broken or is it possible that the lever on the end is loose
the bolts at the end are known to come loose
Old 07-04-2007, 07:24 PM
Quote:
Originally Posted by mhg
Is the shaft broken or is it possible that the lever on the end is loose.....
No, the aluminum housing has broken in half. I pulled the column down and saw it. It's the housing that the shift shaft (whatever) goes through.
Jeff
Old 07-07-2007, 02:02 PM
I've got the parts to fix the shifter. The aluminum housing is called a transmission tube. Here are the part #'s that I have:
1F1Z-7212-AA Trans. tube.
F7DZ-7R264-AA Plunger
F3TZ-7L278 Bushing (2)
I Googled the first part number and found several places where this repair has been made. Lincolns and Mustangs use the same parts so this seems to be a fairly common problem with the automatics possibly due to the shift cable thats dry or dragging, causing too much stress on the tube.
Jeff
Old 07-08-2007, 09:10 AM
lostin90s lostin90s is offline
lostin90s is starting off with a positive reputation.
you can swap it in about an hour just did one. I made a temp shifter for under dash and got the part on eBAY was way way cheaper and reaching under dash to shift once in while till it come no biggie.
If in PA I have a new one on shelf LOST
Rear sliding glass on an '89 F-150? Jeff W. 1987 - 1996 F150 & Larger F-Series Trucks 9 11-22-2014 02:16 PM
TRANSFER CASE OR SHIFTER PROBLEM?? kermmydog 1987 - 1996 F150 & Larger F-Series Trucks 7 03-01-2013 11:57 PM
Interior Lamp relay Buzzing jeff_E Electrical Systems/Wiring 2 10-22-2006 07:53 PM
transfer case shifter rattles pihlboy 1973 - 1979 F-100 & Larger F-Series Trucks 6 06-14-2005 02:21 PM
Looking for aftermarket shifter for 95 E4OD...? sdunham Clutch, Transmission, Differential, Axle & Transfer Case 0 03-21-2005 02:13 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
