2002 f-350 automatic transmission overheating
I have a 2002 f-350, and I was pulling my 5th wheel home the other day and the automatic transmission temp gauge started to climb into the yellow caution area. I was coming up a steep grade out of a canyon, but I had the truck out of overdrive to help the transmission out, but it still started to over heat. Any idea as to why, and how do I fix it.
Prints,
It could be a bad sender for trans gauge. Mine started reading 200+. Take out the sender and ground the threads of the sensor to the the tranny using alligator clips. Take the sensor with a thermometer and put it in boiling water. With the key on (yes have someone help you) check the gauge and the thermometer. Mine was 50 degrees off. Called Banks and got a new sender for $18.00. Problem solved. Good luck. Tom
66 sandrail
01-03-2017 05:31 PM
HD6179
05-05-2016 10:31 AM
