Go Back   Ford Truck Enthusiasts Forums > Other Fords > Ranchero and 1961 - 1967 Econoline
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-04-2007, 09:39 AM
61Econoline is starting off with a positive reputation.
Unhappy Generator light on ALL the time...
never had a generator problem with this truck... now the light came on several days ago... my wife uses the truck to get to work (1 mile away)
'don't have a repair manual, but have checked:
*the battery: 12.67 V - does not change voltage when the engine is revved
*fan belt for the generator: it's tight and it spins the gen.
*the voltage regulator: the bottom "coil" connects to the battery and then pushed in the GEN light goes out, but the voltage does NOT increase (at the battery) when the engine revs
...so, how do I check the VOLT.REG, and GEN to determine which is not working properly? Is there a way of "adjusting" the VOLT.REG.? I'm "in-the-dark" without "maintenance procedures" - I'm willing to fix it, I just don't know how...
Thanx,
Ron
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-04-2007, 08:16 PM
fl1a is starting off with a positive reputation.
You might want to put this question up on the "misc." forum in the electrical systems thread, also.
  #3 (permalink)
Old 07-05-2007, 01:39 AM
pfogle's Avatar
Village Idiot
pfogle is gaining momentum as a positive member of FTE.
I'd start by making sure that the regulator is grounded well. Take a lead from the battery and attach it to the body either close to or on the actual bolt that holds the regulator in place. If that doesn't fix it then you probably have a bad regulator, or bad brushes in the genny.
__________________
1992 E150, 351, 1 ton E4OD (RIP)
Courtesy of my WIFE: "Why do they call it 'scruff' when it's more like mini-daggers?"
  #4 (permalink)
Old 07-05-2007, 03:31 AM
Col Flashman's Avatar
Col Flashman is gaining momentum as a positive member of FTE.Col Flashman is gaining momentum as a positive member of FTE.
Could be the 'Brushes' need to be replaced, they do wear-out, don'tcha know.
Could be a Connection has come loose in the system somewhere.
__________________
Cheers
Colonel Flashman
Vermilion '58 Mercury M-100 HP 312 I-6 w/ HP C-4
Blue '58 Mercury M-100 Panel 223 I-6 w/ M-O-M
Black 1893 Henry Ford Quadra-Cycle (replica)
My Replies Are Not Meant In An Offensive Way.... Ever, They Are Merely.... Straight Answers or Comments
  #5 (permalink)
Old 07-05-2007, 05:06 AM
NumberDummy's Avatar
Ford Parts Guru
NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.NumberDummy has a spectacular reputation.
Most autoparts stores carry new brushes and bearings. The cost is about 20 bucks. As Col Flashman pointed out, the generator brushes are prolly worn down to nothing. When that happens, the generator will not charge.
Shade tree mechanic: The older voltage regulators do stick on occasion. Rap your knuckles on the cover a coupla times, see what happens.
__________________
Bill / Retired Ford Parts Manager ~ 1962/1997
Part Number Research: Trucks: 1928/2002 / Cars: 1928/2003
1963 Galaxie 500XL / 1965 F100 / 2008 Fusion S / 2008 Edge SEL
  #6 (permalink)
Old 07-06-2007, 03:11 AM
ford390gashog's Avatar
ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.
Here is the brush kit FX34 www.kragen.com but it shows the bearings are discontinued.
  #7 (permalink)
Old 07-06-2007, 06:18 AM
Ford Parts Guru
A8AZ-10094-B .. Replaced by >> C9ZZ-10094-A .. Bearing: Generator End Plate (Motorcraft GE-21)*
B6A-10095-B .. Bearing: Generator Rear (Motorcraft GE-4)
*Kragen sez Obsolete? This bearing has also been used in alternators since 1969...and is still used today.
BIL is VP of Checker (Kragen)....mebbe I'll call him up and have him update the info.
__________________
  #8 (permalink)
Old 07-08-2007, 10:39 PM
'finally had a chance to remove both the volt.reg. and the generator.
after opening up the GEN 'noticed the brushes are worn pretty good but the commutator that they ride on is *R*E*A*L*L*Y* worn down...
'called *every* auto parts store in the phone book: nobody (on a Sunday) has a replacement. Tomorrow I'll start calling "auto electrical" places to see about getting another one...
Suggestions for places to try??
  #9 (permalink)
Old 07-09-2007, 05:40 PM
Jimbare's Avatar
all alone in the world
Jimbare is gaining momentum as a positive member of FTE.
yours can probably be turned down and flattend. anyone that rebuilds electrical stuff should be able to fix you up.
__________________
jim
underated and overworked.
  #10 (permalink)
Old 07-10-2007, 08:34 AM
Jimbare,
there was no fixing THIS commutator - it was worn down almost 40% !!! I don't know *how* it was working as long as it did... I've had my 61 'Connie since March 1984, rebuilt quite a few things along the way, but the last time I *looked* at the generator was ~1989 when I changed brushes... 'found an "automotive electric" place not too far from my shop and they completely rebuilt it in 1/2 a day !
'have had quite a few cars and motorcycles in this time, but the one "constant" was the '61.
My cousin's girlfriend, back in 1984, named the truck "Homer" - it was *not* good looking (faded paint, bad wheels/tires, etc) and she didn't want to be seen in it... the name 'stuck'...
  #11 (permalink)
Old 07-10-2007, 02:49 PM
There is a used, pulled 61 Falcon generator on ebay motors for sale. I can find it
again if youre interested.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
