Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Performance and General Engine Building
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 08-30-2002, 01:24 PM
G_SHARPE is starting off with a positive reputation.
Post fuel injected vs. regular carborator / swap ??????
I Have a 1989 F-250, with a electronically fuel injected 351W. Can this engine be remove and replace with a 351W with a regular type carborator?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 08-30-2002, 07:12 PM
canzus is starting off with a positive reputation.
Why??
Steve & the Rockette
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'73 MG B GT 2.6L V6(Ford)
'98 Contour SVT 2.5L V6 (Mods)
'01 ZX2 (No Mods yet)
__________________
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'74 Capri 2L
  #3 (permalink)
Old 09-03-2002, 08:44 AM
I know alot more about carburated engine than I do fuel injected. The engine in question has a problem and I'm not sure what it is. It could be a head gasket, EFI computer could be bad, fuel system problem, i just don't know. I can replace the whole thing (engine) for about $1000.00. So what i am wondering is "Can I drop a 351w carborated engine in and have it work like a carborated engine should or will their be a problem because the truck is set up for fuel injection right now????
  #4 (permalink)
Old 09-03-2002, 09:42 PM
88f1504x4's Avatar
88f1504x4 is starting off with a positive reputation.
[updated:LAST EDITED ON 03-Sep-02 AT 09:43*PM (EST)]All you need is to get a new intake manifold(go to the junk yard or something) try to find a throttle cable why you are there. Then you take out all your FI stuff and take off the manifold and put the carberated intake manifold on, put the carb on, then set up your throttle cable, simple as that.
__________________
lXl People Like Us lXl
78 F-150 4x4 351m
02 F-350 XLT C/C 4x4 7.3L 5" MKO Straight Pipe 35x12.5x17 BFG Mud Terrain, 17" moto metal 951 gloss black, 2.5" rough country leveling kit, Superchips, 5.6k mod, K&N
87 Chevy Silverado 4x4 8" lift 38.5" tsl's
  #5 (permalink)
Old 09-04-2002, 12:19 AM
cajunbronco is starting off with a positive reputation.
Not exactly,you will need to put in a low pressure fuel pump and modify the pick up tube,or put in a regulator to drop the fuel pressure.A carb sysytem can't run at 35 psi.If you have an auto tranny you will need either a kickdown rod or if it's an AOD a tv cable hook up.You will also need a duraspark distributor and ignition box or an aftermarket ignition(msd).The cheapest way would be to find a carb truck you can raid for the parts.
Billy
  #6 (permalink)
Old 09-04-2002, 07:33 AM
thanks for the information cajunbronco & 88f1504x4.
  #7 (permalink)
Old 09-04-2002, 05:28 PM
You seem to a bright type of person,
EFI isn't that hard to figure out, get
a decent manual, read it, it's not
rocket science, no more difficult to
get your brain around than a Holley...
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'98 Contour SVT 2.5L V6, That blowed up real good...
__________________
'63 F100
'68 F100
'72 Capri 2L
'73 Capri 2.6L V6
'74 Capri 2L
  #8 (permalink)
Old 09-05-2002, 06:51 AM
Lightning2Fast is starting off with a positive reputation.
__________________
94 lightning
ys trim vortech renegade
intercooled
detroit locker
ladder bars
42# injectors
level 10
2800 stall pi converotor
psp tuned
11.51 @ 117
501rwhp 647rwtq
STILL SPEED DENSITY
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
