greasing u joints
greasing u joints
I dont know much about drive shafts/u joints but I do know that my front u joint needs some grease, it is squeaking under acceleration in 4x4. Does any one have a link with pics or able to explain exactly where/what to grease and what type of grease? I mean is there a grease zert some where to look for? How do I tell if the u joint is shot and should just be replaced?
Also how is the front drive shaft removed? I'm looking at a set of headers and in the instructions it says to remove the front drive shaft. Thanks guys.
On the axle u-joints if you cant find the grease zerks they are probably the greaseless type or there is a little plug/bolt looking thing screwed into the end of one of the caps and you remove that and temporarily install a grease zerk the put the plug back. You dont leave the zerk in since there isnt enough room for it. One way to tell if the u-joint is shot is to have the hubs locked and t-case in neutral and safely jack up the truck tire and rotate the wheel back and forth. If the u-joint looks tight then it should be ok but if the u-joint goes clunk-clunk then replace it.
I dont know why you need to remove the front drive shaft for headers but you just unbolt the little u-joint retainers and remove the drive shaft. Be sure you dont drop the u-joint cups cause the little needle bearing will go all over.
Originally Posted by ford390gashog
If the u joint squeaks its trash. There is no saving it from that point its time to replace it.
Originally Posted by Mil1ion
Not all U-joints come wioh Zerks.
You have to physically look for them.
If you have one at each end...
Put some in anyway.. when the grease come out the seal ..stop the grease gun.
on
If ya replace the axle joints put in ones with a Zerk that Has an inverted nipple (watch the parts counter girl blush when ya ask for that). Than get a nipple adapter to fit on yer grease gun. These also work better on the double u joint on most front drive shafts. always get greaseable u joints. Most shops and Stealer's will put in the non greaseable ones cuz they are cheaper and garrenty that you will be back soon.
on
I've got a lot of non greasable joints in my time and I have never seen a solid one. I have drilled out the ones without and taped them for a Zerk. If there is solid ones out there for these years of tuck than I have never seen them. They are hollow and filled with grease when assembled. I can't imagine one with no lubricant lasting very long no matter what it was made out of.
The original U-joints on my '75 F150 had -no-zerks and outlasted the engine and "only showed any sign of wear" (according to the drive shaft guy:) "is because the carrier bearing went bad first". YMMV
An out of balance drive shaft and other vibration will kick-the-crap out of the U-joints in no time. :/
Yeah, I'm a "greezzer" and I know that grease only-slows-down whatever wear is going to happen anyway.
Alvin in AZ
Alvin in AZ
on
1 Post
Originally Posted by Alvin in AZ
The original U-joints on my '75 F150 had -no-zerks and outlasted the engine and "only showed any sign of wear" (according to the drive shaft guy "is because the carrier bearing went bad first". YMMV
Alvin in AZ
Alvin in AZ
