I don't have 79 specs available, however here are 77 and 81 specs from the F100/F150 history book, 1953-1996 by Robert Ackerson -
77 302 136hp @3600 rpm 49 state
no california 302 listed
77 351 162hp @3800 rpm F100 163hp at 3800 rpm F150 49 state
77 351 165hp @3800 rpm F100 161hp at 3800 rpm F150 Calif
81 302 133hp @3400 rpm 49 state or calif ? Not clear
81 351 136hp @3000 rpm (F150 only) 49 state or calif ? Not clear
Sorry these are not 1979 specs, i wish I couold answer your question directly, but I thought these would give you some idea, although not the exact numbers you were looking for.
David
__________________
Ford trucks I have PROUDLY own/owned ALL of them including the Couriers are truly FORDS
78 F250 460 C6 - sold
79 Courier 2.3L 5sp - sold
83 F250 SCab 6.9 4sp - sold
86 F150 5.0 SCab EFI AOD - sold recently
86 Bronco 5.0 EFI AOD - sold recently
75 Courier 1.8L 4sp
Yeah.. 1979 was the peak of the oil embargo, Detroit lowered the compression, installed milder cams and redicuously restrictive exhaust systems in an attempt to improve fuel milage. All they really did was make the land yacht cars of the day painfully slow and lumbering. The upside is you can almost double an engines output with a decent exhaust, cam and carb upgrade.
