Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-03-2007, 04:17 PM
captain p4's Avatar
I'll sleep when I'm dead
captain p4 is a splendid one to beholdcaptain p4 is a splendid one to beholdcaptain p4 is a splendid one to beholdcaptain p4 is a splendid one to beholdcaptain p4 is a splendid one to beholdcaptain p4 is a splendid one to beholdcaptain p4 is a splendid one to behold
sky manufacturing shackle flip kit
I started to install it yesterday and ran into a few problems..
1) does anyone have the part # for passenger side rear shackle on my '78? I had to cut both ends of the bolt off to get it out. I'm going to try the air hammer on a little later, but doubt I'll have much luck.
2) The brackets are too big in the back.. they hit my bumper brackets. Can I safely cut some material out of the sky pieces so it will clear my bumper brackets or does anyone have some other suggestions?
thanks for any tips/help
__________________
-Paul
86 Rustang 5.0/5spd.. and full of bootyfab.
78 Bronco 400 c6 np205 d60/sterling10.25
OBA, 36" hummer tires, some other stuff
2003 F350 Supercab shortbed FX4 6.0 PSD
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-03-2007, 06:40 PM
fishmanndotcom's Avatar
fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.fishmanndotcom has a great reputation on FTE.
as beefy as they are i garauntee you can. just dont go hacking out chunks!
just go to ford and tell them what you need. i would be willing to bet they are the exact ones i just bought for $32 for the pair and they fit like 76-96 trucks with 2.5" rear springs. but dont hold me to it.
-cutts-
__________________
Quote:
Originally Posted by Ingolf View Post
yeah, im a rich kid. but hey, i dont hate my parents for it. my dad drives a lambo.. so what the **** do i care LOL
  #3 (permalink)
Old 07-03-2007, 07:21 PM
captain p4's Avatar
I decided to cut the bumper brackets instead. Bumper doesn't get used for anything and I have tow points bolted on the frame, besides it was only about 1/4inch I needed to cut out.
The shackle is giving me fits though. I found them on JBG so I might just go that route, as I'm sure the dealer will have to order it anyway. I tried drilling and the air hammer on the thing and it won't budge.
oo and before I forget, which hole is recommened for better shackle angle on the sky pieces? I know this has been covered before in here, but I can't seem to pull up the thread with the search function.
__________________
-Paul
  #4 (permalink)
Old 07-03-2007, 07:31 PM
dude, its FTE
i used the forward most hole and my shackle angle was decent. had to move the front mounts to get it just right!
-cutts-
__________________
  #5 (permalink)
Old 07-04-2007, 04:46 PM
crazyredneckanyhow's Avatar
meloncholy
crazyredneckanyhow is a splendid one to beholdcrazyredneckanyhow is a splendid one to beholdcrazyredneckanyhow is a splendid one to beholdcrazyredneckanyhow is a splendid one to beholdcrazyredneckanyhow is a splendid one to beholdcrazyredneckanyhow is a splendid one to beholdcrazyredneckanyhow is a splendid one to beholdcrazyredneckanyhow is a splendid one to behold
Ok ive been looking at those shackle and i got a question. What are you guys talkin bout the holes? Dont they just bolt right up to the factory holes?
  #6 (permalink)
Old 07-04-2007, 05:32 PM
captain p4's Avatar
Yeah, you just drill the factory holes out to 1/2inch and it bolts right up.
On my truck the pieces didn't clear the bumper bracket so I had to cut some of that off.
On the sky piece there are two holes you can use to mount the spring shackle depending on where you want your shackle angle to be. I believe the desired angle is 45*, but i'm sure fishy will correct me if I'm wrong on that..
__________________
-Paul
  #7 (permalink)
Old 07-04-2007, 06:47 PM
RawPower's Avatar
RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.RawPower has a very good reputation on FTE.
Its personal prefference/imtended use... 45º is ideal for most applications, including street usage. I have my rears at 40-ishº, I won't tell you what my fronts are at
__________________
1993 F350 7.3 IDI, ZF S5-42, TS Div205, OEM/welded Rock's, 46's, 145" wheelbase
  #8 (permalink)
Old 07-09-2007, 02:53 PM
KubotaOrange76's Avatar
KubotaOrange76 has a very good reputation on FTE.KubotaOrange76 has a very good reputation on FTE.KubotaOrange76 has a very good reputation on FTE.
usually to get a good shackle angle the sky brackets need to be moved foward a bit from the factory holes
__________________
2007 Dodge 3500 4x4 DRW G-56 5.9 QC 46,500k CM flatbed "miscellaneous efficiency mods"
1989 f-150 2wd xl lwb reg cab 300-6 2.73 195k..beat on every day!
Check out my gallery to see my old truggy.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
