Number Dummy - Page 2 - Ford Truck Enthusiasts Forums
Number Dummy
Old 05-06-2013, 04:00 PM
NumberDummy's Avatar
NumberDummy NumberDummy is online now
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by raerjim View Post
Hey Bill, would you ID this trans for me Sir? #1A-7006-A
Also aquired a nice looking Y-block. block # EVB-6015-C (maybe G) What displacement is that? Thanks. youdaman
1A-7006-A is a Ford 3 speed manual column shift without 1st gear syncro, used 1951 thru 1962 Passenger Cars/F1/F100/F250.
I have no cross reference catalogs for Y block casting numbers that have 3 digit prefixes.
Old 05-06-2013, 08:35 PM
bigwin56f100's Avatar
bigwin56f100 bigwin56f100 is online now
bigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud ofbigwin56f100 has much to be proud of
EBV is a 1955 truck with the small cam bearings 239 cu in
Old 05-06-2013, 09:28 PM
theodore/teddy's Avatar
theodore/teddy theodore/teddy is offline
Refyred
theodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to beholdtheodore/teddy is a splendid one to behold
Did you notice the date on this post, probably not.
LOL
Old 05-07-2013, 06:04 AM
Quote:
LOL
A dug up the thread to ask a question in post 15. I was reading thru 'New Posts' when I spotted it, didn't pay attention to date.
Old 08-10-2014, 03:06 PM
robinc2 robinc2 is offline
robinc2 is starting off with a positive reputation.
Hey, pardon my ignorance to this group of experts, i got your name from another thread and found you and could figure out how to start a new thread with you so i'm popping on a pre-existin conversation with a new question that is unrelated to this thread (sorry about that).
Here is my question. I have a 1966 F100 300 cu inch 6 cyl with a manual T18 transmission. I'm trying to fix the "slop" in the shifting pattern. When i started a new thread with this question your name came up. Apparently there is a pin i can replace that should take alot of the slop out of the shifting pattern. Do you have the Ford part # for this pin? Do you have any pics of it and the transmission so i can replace it myself?
Many thanks for any assistance....Chris
Old 02-20-2015, 12:28 PM
gordelgordo gordelgordo is offline
gordelgordo is starting off with a positive reputation.
gordelgordo
Bill, could you help with these ford yblock part numbers? Timing cover number EBV 6059 G and water pump ECW 8505 ? Can you tell what engine they came off of?
Thanks
gordelgordo
Old 02-20-2015, 08:05 PM
harleymsn's Avatar
harleymsn harleymsn is online now
harleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to allharleymsn is a name known to all
Quote:
Thanks
gordelgordo
I'm not Bill, but you really should start a NEW thread.
EBV6059G is a timing cover for a 1955 239 Y block truck engine
ECW8505A is a casting number for an off brand waterpump. they are marketed on ebay by a Chevy guy as being for a flathead, which they are NOT for, but they are actually the same or at least they look to be copies of a B6A8501B which is a water pump for a 56-59 272,292 or 312 Ford
Help....Drum to drum distribution block needed tbruz 1973 - 1979 F-100 & Larger F-Series Trucks 10 12-15-2015 06:40 PM
12 volt 40 amp Generator 1950FordF1 WTB - Parts & other 0 05-14-2015 03:59 PM
D8VE BLOCK INFO baddad457 Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 15 03-06-2015 11:01 PM
fe engines ford390gashog FE & FT Big Block V8 (332, 352, 360, 390, 406, 410, 427, 428) 12 11-13-2004 01:15 PM
A/C Unit big block power 1967 - 1972 F-100 & Larger F-Series Trucks 4 08-02-2002 02:42 AM
Tags
1a, 1a7006a, 7006, 7006a, assigning, dummy, ford, manual, number, numberdummy, numberdummycom, numbering, numbers, part, standard, transmission
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
