Quote:
Originally Posted by scottie2hottie
Just wondering what ya'll think about this situation....when the rev limiter cuts out is this gonna cause some issues?
It's potentially a very dangerous situation for your pistons at a minimum. Nitrious flowing in without fuel is definately bad.
Install an aftermarket rev limiter and a relay, and use that relay to cut off the nitrious at the same RPM, or a "hair" before.
Then everything cuts off rather than just the fuel.
or, edit the EEC data tables and increase the rev limiter value.
