What steps to change to B20?
Hello folks-
I have been running diesel with Power Service fuel additive in my 7.3, but I am very interested in switching over to B20. I have recently found a few stations in my area that are supposed to be carrying it, so at least locally, I should be able to find it.
I have a few questions however-
If you are travelling, what do you do if you can't find a biodiesel pump? Is it OK to go back and forth with regular diesel?
Are there any steps I need to take to prepare my truck to run Bio?
Do I need to use Lucas or some other product as a 'top lube' additive?
Are there any threads here in this forum that can help clarify some basics for a beginner and give me some directio on getting started?
All help is appreciated!
The only suggestion is to carry an extra fuel filter as bio will clean out your system and shove all the junk into your filter. Swithing back and forth will not affect your engine whatsoever. Youll want your addatives for the low sulfer diesel but b20 overcomes all of the lubricity factors. No addatives for b20, addatives for number 2.
Mike...you don't need to change a thing, or do anything to prepare for using B20, or any biodiesel mix (using straight unprocessed vegetable oil is different...that's where you have to make some changes). Your PSD is all ready to go. Fuel lines and associated gaskets and seals are all made of materials compatible with biodiesel in the newer models from around 1996 on.
No additives needed!!
When you can't get BD on the road, you can go right back to petro diesel with no problems...that is if YOU can stand it after running BD. The truck can take it, but I can't!! You'll probably find that the truck likes BD better, too, I'll be installing an extra tank in the bed when I start traveling beyond BD suppliers.
Don't hesitate to try some BD!! You, and your truck, will love it!
You have a much greater chance of loosing a seal from running straight ULSD than you will ever have running Bio-Diesel, Ive run it now for over 3 years, and trust me I am a firm believer. My truck runs quieter and smoother.
one note though; I was running B35 this winter and for the first time ever it did gel up on me. But that was my own stupidity for not adding any additives.
I started running B20 in my 02 at 155,000 miles. I checked the filter every week because I was scared of it plugging up, but never noticed it getting dirtier than normal. Like others said switching back to #2 is no problem just have some additive handy if you're going to burn several tanks of it to help with lubricity.
Originally Posted by mongo75
Fat- I've never understood "B99"- why bother putting just 1 gal of #2 into 100 gallons of bio??
Gotcha- it don't matter to me as I have yet to find a commercial bio station here in so cal
