TPS kickin my *** - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
TPS kickin my ***
Old 07-03-2007, 12:38 AM
syjl syjl is offline
syjl is new and has a neutral reputation at this point.
TPS kickin my ***
Hey Guys,
I received my Dorman TPS today (699-200). Looks right but isn't. When you try to mount it, you have to preload the mechanism to get the pedal tab in the slot. Unfortunately, this means that the truck is all confused. It will run but shifts way early when and if it moves. It often won't move. Then the check engine light comes on and the OD light flashes. Is the only way to fix the TPS (which is the code that keeps showing up) to buy it from Ford or find it in the junkyard? I don't want to pay the $400 that Ford wants for the assembly but this truck has not functioned right since I bought it. Any other good (cheaper) ideas?
Old 07-03-2007, 02:02 PM
Riata_Ag's Avatar
Riata_Ag Riata_Ag is offline
Riata_Ag is starting off with a positive reputation.
I believe I have read on here before that there is a TPS that will work on your truck that is for a different year model that is cheaper........
Keep searching the forums or wait a little and someone will chime in that has more experience with this, but I do remember this being discussed before and I think there is a different TPS you can buy thats cheaper, but wait for someone who knows for sure to chime in.......
ra
Old 07-03-2007, 02:29 PM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
What year is your truck? Here are the part number for the different pedal assemblies
Throttle Assembly (Includes Pedal, TPS, & IVS) 94-97
(Ford) F5TZ-9F836-A (f-Series) 94-95
(Ford) F6TZ-9F836-AA (F-Series) 96-97
(Ford) F5UZ-9F836-B (Econoline)
Old 07-03-2007, 02:38 PM
Tim,
It is a 97 but that assembly is $400. I think I am going to go back to autozone and get their TPS for $30 and try to modify it so that I can bolt it in without preloading it which is the problem with any of the TPS's I am getting. I am just trying to avoid the $400 bill for the pedal assembly.
Old 07-03-2007, 03:14 PM
bdrummonds's Avatar
bdrummonds bdrummonds is offline
bdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud ofbdrummonds has much to be proud of
Do a search over in the 99-03 section I remember someone posting that the Sensor is now avail seperatley from the pedal assembly. Ill try and post back if I find that thread. hold on.....
Ok here it is. http://www.ford-trucks.com/forums/62...osition+sensor
Hope this helps
Brandon
Old 07-03-2007, 03:25 PM
tjbeggs's Avatar
Well it still alot of money but here is a 97 assembly for $220. I picked one up a few weeks ago for $75 used. Might keep your eyes open on ebay. Also The diesel stop has a very good classified section. Thats where I got mine.
Old 07-03-2007, 03:52 PM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Question
Quote:
Originally Posted by syjl
Hey Guys,
Maybe you need the 699-201 from Dorman?
Old 07-03-2007, 04:05 PM
Thanks for looking guys.
bdrummonds, That is the thread I used to get the part from Dorman, Thanks
tjbeggs I will keep looking on ebay and the diesel stop but may just pay the $220
roentgeep The 699-201 is for the newer trucks. Do you think it would work?
I went back to autozone and got the $30 one which is the same as the Dorman product. I am going to try to modify it to see if I can make it work. I have requests out to the junkyards too. Such a small part causing such a big problem.
Old 07-03-2007, 04:08 PM
RÖENTGEEP's Avatar
FOREIGN GURU
Arrow
syjl : I really dont know, you should ask them at Dorman.
Sorry.
Old 07-03-2007, 06:33 PM
Action4478 Action4478 is offline
Action4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputationAction4478 has a superb reputation
Old 07-03-2007, 06:46 PM
It looks like they have the assembly but with no returns, it is scary if it doesn't work. It's a shame someone doesn't sell the correct TPS for the truck. I am trying to leave in the morning to tow the fiver to the Grand Canyon to get out of the 116 degree heat tomorrow. But it makes me nervous being out on the highway without total confidence in the truck. I will let you know if the mod works tonight.
Old 07-03-2007, 07:38 PM
tjbeggs's Avatar
Rick the one at Diesel site is more than the powerstroke shop. They want 263 for 96-97 and 640 for the 94-95 one. The price changes witht he drop down menu.
BTW, Rick do you know of anybody looking for an older diesel cargo van. 93 E-350 with a 7.3 IDI. If so I got one for sale. I tell you about it next time I stop over.
Old 07-04-2007, 11:46 AM
Tried to modify the autozone one but no dice. It just jammed and held the engine open. I cleaned up the stock switches and it will have to do for this trip. I will search the Utah junkyards while I am up there and the diesel sites when I get back unless TJ will part with his pedal assembly. Thanks for the help guys.
Old 07-04-2007, 09:49 PM
tjbeggs's Avatar
Well I'll tell ya what. If you look around locally and can't find one I will consider selling the one I have to you. In the mean time I will contact the guy I bought mine from and see if he has anymore. I just hope that after if I sell you mine murphy doesn't apy me a visit and have my pedal go out! But let me know if you can't find one and we can work something out!
Old 07-05-2007, 07:39 AM
tjbeggs's Avatar
Good news! I found another one for you! I will just buy it and hope you get the message. If you don't need it I am sure somebody else will soon. Let me know
Stall Strokerboy73 1999 - 2003 7.3L Power Stroke Diesel 1 03-23-2016 05:04 PM
Very high idle, Air Bypass Valve vs. Lost TPS 87-XL-Squared 1987 - 1996 F150 & Larger F-Series Trucks 7 02-26-2016 08:52 AM
Adjusted my TPS, does this sound right? Golden Helmet Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 05-15-2015 08:48 PM
Throttle cutting out at low RPMS TPS & IVS syahj04 1999 - 2003 7.3L Power Stroke Diesel 10 02-09-2015 06:01 AM
TPS - Throttle Position Sensor FYI PaysonPSD 1999 - 2003 7.3L Power Stroke Diesel 72 10-23-2013 04:42 PM
Tags
200, 699, 699200, 699201, 95, bed, build, doorman, dorman, e250, f350, f5tz9f836a, flat, ford, senor, skirted, tps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
