TPS kickin my *** - Page 3 - Ford Truck Enthusiasts Forums
1994.5 - 1997 7.3L Power Stroke Diesel SPONSORED BY:
TPS kickin my ***
  #31
Old 06-12-2014, 06:06 PM
wolff7.3 wolff7.3 is offline
wolff7.3 is starting off with a positive reputation.
So I got one from dorman and it worked for about two months now its back to shuttering between 30-40 mph. But only when truck is cold, Kinda weird. But I can't find an oem unit on ebay or anywhere, does anyone know of a site to go to find one? These things are a pain!
  #32
Old 06-12-2014, 06:34 PM
BBslider001's Avatar
BBslider001 BBslider001 is offline
BBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to behold
I am not sure the shuddering would have anything to do with the TPS. Maybe someone else will chime in, but my experience has been that they either work or they don't.
  #33
Old 06-13-2014, 10:36 AM
syjl syjl is offline
syjl is new and has a neutral reputation at this point.
I use rockauto.com or amparts.com for online parts. I have to agree that your issue doesn't sound like a tps or cps.
  #34
Old 06-13-2014, 11:08 AM
madpogue madpogue is offline
madpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to beholdmadpogue is a splendid one to behold
^^^^^ +1; to pin it on the pedal position sensor, you'd have to get a live feed of its value (volts or percent) at the time you get the shudder. Something like AE that will log the value over time would be of use here. But I'd bet a nickel it would show a normal value. CPS is a somewhat more likely suspect, since it's out there under the hood and bolted to the block, and more subject to different behavior based on temperature.
Stall Strokerboy73 1999 - 2003 7.3L Power Stroke Diesel 1 03-23-2016 05:04 PM
Very high idle, Air Bypass Valve vs. Lost TPS 87-XL-Squared 1987 - 1996 F150 & Larger F-Series Trucks 7 02-26-2016 08:52 AM
Adjusted my TPS, does this sound right? Golden Helmet Pre-Power Stroke Diesel (7.3L IDI & 6.9L) 3 05-15-2015 08:48 PM
Throttle cutting out at low RPMS TPS & IVS syahj04 1999 - 2003 7.3L Power Stroke Diesel 10 02-09-2015 06:01 AM
TPS - Throttle Position Sensor FYI PaysonPSD 1999 - 2003 7.3L Power Stroke Diesel 72 10-23-2013 04:42 PM
Tags
200, 699, 699200, 699201, 95, bed, build, doorman, dorman, e250, f350, f5tz9f836a, flat, ford, senor, skirted, tps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
