TPS kickin my *** - Page 2 - Ford Truck Enthusiasts Forums
TPS kickin my ***
Old 07-08-2007, 09:31 PM
syjl syjl is offline
syjl is new and has a neutral reputation at this point.
TJ. Consider it sold. I will also pay for express shipping. We were at the Grand Canyon all weekend without outside communication ( a good thing sometimes). The truck ran good on cruise control but had issues when I needed throttle control. I am going to call it a day but will post pictures of the good part of the weekend and the Found On Road Dead part of the trip back to Vegas. Thank you so much. Anytime you want to come to Vegas, you have a place to stay here at the house. I will be in touch so I can send you the money. Thanks again. You restore my faith in people and as a Fisher of Men, you have much of which to be proud. Talk to you tomorrow.
Old 07-14-2007, 01:26 PM
Problem solved by tjbeggs. Thanks Tim, However, I would like to pass along some info so others can avoid the hassle. The link below has a picture of the 3 TPS's that I tried so I wouldn't have to go to the stealership. The Ford TPS is the only one that will work. Both the Wells and Dorman TPS's have the angle wrong where the pedal tab fits into them. This causes the voltage to be incorrect and cause the tranmission to be confused. You must obtain an original TPS via ebay, etc. or pay the dealership $400 ($800 if it is a newer model). Don't waste your time trying to use something else. It just won't work.
http://www.flickr.com/photos/syjl/809786439
Old 07-15-2007, 12:17 AM
Neal 97 250's Avatar
Neal 97 250 Neal 97 250 is offline
Neal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud ofNeal 97 250 has much to be proud of
tj is the bomb IMO. Congrats on the fix. Funny, I am in Parker AZ. now till next Friday. I went thru Henderson you have beautiful land out here. The Colorado river brings in the wild ones though.
Thanx for the info, as I understand it the ford is the only one that works even though one of them looks similiar.
Old 07-16-2007, 11:20 AM
RÖENTGEEP's Avatar
RÖENTGEEP RÖENTGEEP is offline
FOREIGN GURU
RÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to beholdRÖENTGEEP is a splendid one to behold
Question
syjl: so you cant modify that wrong angle in any way?, because the Dorman and the original looks very similar but the bushings and the angle for the pedal tab.
Old 07-16-2007, 08:27 PM
jboard's Avatar
jboard jboard is offline
jboard is starting off with a positive reputation.
My TPS messes up every 5 mos or so and you can actually bent parts of it and shim parts of it to keep it working.
--------Jeremy
Old 07-16-2007, 09:47 PM
I did drill new holes in the Wells (autozone) TPS because it was only $30. However, at one point it held the throttle open (jammed) and that was a safety issue for me. The Dorman unit at $70 including shipping was not worth the effort when I could get a complete used OEM assembly for $100. The truck now shifts and runs correctly without the unknown factor of pulling into traffic not knowing if the pedal would work or the transmission would shift to 3rd immediately.
Old 10-02-2010, 10:00 AM
bscttusmc bscttusmc is offline
bscttusmc is starting off with a positive reputation.
F5TZ-9F836A
i have one of these hard to find 94-94 pedal assembly F5TZ-9F836A on ebay
Old 05-19-2014, 08:53 AM
Gentlemen, I find myself needing a TPS again for my 1997 F350 diesel. I purchased one from tjbeggs 5 years ago but it is acting up again. As you can see by this thread, only the Ford one will work unless someone knows of a new source. Thank you.
Jeff
Old 05-19-2014, 10:21 AM
BBslider001's Avatar
BBslider001 BBslider001 is offline
BBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to beholdBBslider001 is a splendid one to behold
I put a Dorman 699-200 in my truck last summer. It has worked fine since then. Maybe they made them better? You can get them on Amazon for less than $40 if you are willing to try one again.
Old 05-19-2014, 11:05 AM
tjbeggs's Avatar
tjbeggs tjbeggs is offline
tjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to alltjbeggs is a name known to all
I would say your best bet is the Ford unit- They can be had on ebay much cheaper- Just last week I had a customers SD in that had a Dorman TPS in it- It failed- new dorman worked fine, I still recommended the Ford unit. In my experience Dorman parts are a big hit or miss proposition- The dorman may make a good "get you down the road" part but not a fix it for the long haul part- I use many dorman parts in my daily operation- some are good, some I would not trust for a second
Old 05-19-2014, 02:11 PM
I would love a Ford one, but I thought they were really pricey? Have they come down?
Old 05-19-2014, 02:33 PM
tjbeggs's Avatar
Quote:
No about $200 on ebay which is less than my cost wholesale
  #28
Old 05-19-2014, 02:55 PM
1) I am returning the one I got from OReilly's which says Ford on it but isn't even close.
2) I have ordered one from AM Autoparts - After Market Auto Parts - Headlights, Mirrors, and More for $50 as a backup but I doubt it will work
3) I will comb the junkyards here in Vegas for one and then try ebay.
Thank you for the usual great support and I will keep you posted.
Jeff
  #29
Old 05-23-2014, 01:46 PM
Gents, The TPS from AM Autoparts turned out to be the Dorman 699-200. I put it in and it seems to work fine. Perhaps, like tjbeggs suggested, some of them are good and some not so much. The one I purchased 5 years ago absolutely did not work. Thanks for your help.
  #30
Old 05-23-2014, 09:02 PM
Glad ya got it fixed!
TPS - Throttle Position Sensor FYI PaysonPSD 1999 - 2003 7.3L Power Stroke Diesel 78 03-08-2017 09:52 PM
Stall Strokerboy73 1999 - 2003 7.3L Power Stroke Diesel 1 03-23-2016 04:04 PM
Very high idle, Air Bypass Valve vs. Lost TPS 87-XL-Squared 1987 - 1996 F150 & Larger F-Series Trucks 7 02-26-2016 07:52 AM
Help tps problem 1badshovel Clutch, Transmission, Differential, Axle & Transfer Case 6 04-17-2011 06:01 PM
86 F150 EFI 302 -How to Adjust TPS D Harry 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 4 08-16-2003 04:25 PM
Tags
200, 699, 699200, 699201, 95, bed, build, doorman, dorman, e250, f350, f5tz9f836a, flat, ford, senor, skirted, tps
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
