Go Back   Ford Truck Enthusiasts Forums > Misc. > Offroad and 4x4
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Offroad and 4x4 SPONSORED BY:
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-02-2007, 11:02 PM
crazyredneckanyhow's Avatar
meloncholy
crazyredneckanyhow is a splendid one to beholdcrazyredneckanyhow is a splendid one to beholdcrazyredneckanyhow is a splendid one to beholdcrazyredneckanyhow is a splendid one to beholdcrazyredneckanyhow is a splendid one to beholdcrazyredneckanyhow is a splendid one to beholdcrazyredneckanyhow is a splendid one to beholdcrazyredneckanyhow is a splendid one to behold
lift ?s
Ok got a few odd and end ?s. Ok first 79 f-150 with a 9" suspension lift. How big of a tire can i run? Basically a show truck no hard offroad use or suspension flex. Second. Ive got a skyjaker lift off a parts truck. cant find any numbers. Anyidea how to figure out how big a lift it is? I know the truck was a 79 f-150 short bed and with this lift and a 3" body lift it fit 40s. Probably a 6". PO didnt install so he didnt know what it was. Thanks guys dave
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-03-2007, 06:10 PM
flcracker9 is starting off with a positive reputation.
I would think the 79 would be similar to my Son's 86 f150. We installed a 6" skyjacker lift, and 35" tires, and they fit about right. He did cram a tire into the fender when he wit a deep washout with the wheel turned. If you go 9", I would think that 37's would fit fine, 38.5s - 39.5s would work for a show truck that doesn't leave the pavement, although it may look funny.
__________________
74 F250 High Boy, 300ci, Demon 525, EFI maifolds, 260H Cam, 39.5 Swampers
86 F150 4X4, 351, GT40P Heads, 274 Cam, Crane roller rockers, Mac Headers, Demon 725, 35" pro comp muds
03 F250 Super Duty 7.3 Diesel, K&N Intake, Edge W/Attitude programmer, 4" exhaust, 35" Mickey Thompsons
  #3 (permalink)
Old 07-03-2007, 06:14 PM
MBBFord's Avatar
MBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to beholdMBBFord is a splendid one to behold
I have 6" on my 79, and I can fit 39s if I wouldn't flex it.
You should have no problem fitting 42s, just don't flex it.
Also, id depends on how easily those 40s fit....
If they had room to spare, then the lift is probably a 6", but if there isn't much room at all, it's more than likely a 4".
What type of lift does it have in the back? Blocks? how big?
__________________
79 Bronco 400 C6 NP205 D44 9" 4.56 gears Lockers 6" lift and 37" SS Iroks
77 F-100 302 C4 D44 31" M/Ts
04 F150 Lariat Screw 4x4 2"AS 32x11R17 Hankook M/Ts or 34x10.50-17 SS LTBs
  #4 (permalink)
Old 07-03-2007, 06:19 PM
meloncholy
It had blocks in the back. Ill go measure them now. It had plenty of room with the 40s
  #5 (permalink)
Old 07-03-2007, 06:24 PM
meloncholy
ok just went and measured the blocks. One end is 4 1/4" and the other is 4 3/4". Must be angled for redegree of the driveshaft.
  #6 (permalink)
Old 07-03-2007, 06:49 PM
MBBFord's Avatar
Ok, if the truck has a rake(back end higher than front), than it's a 4" lift, but if it seems that the truck is level or even if the bed has a little squat, then it's more than likely a 6".
__________________
  #7 (permalink)
Old 07-03-2007, 08:45 PM
captain p4's Avatar
I'll sleep when I'm dead
captain p4 is a splendid one to beholdcaptain p4 is a splendid one to beholdcaptain p4 is a splendid one to beholdcaptain p4 is a splendid one to beholdcaptain p4 is a splendid one to beholdcaptain p4 is a splendid one to beholdcaptain p4 is a splendid one to behold
I ran 36's on my '78 bronco with no lift.. its currently in a million pieces getting some frame work and lifted 4inches.
__________________
-Paul
86 Rustang 5.0/5spd.. and full of bootyfab.
78 Bronco 400 c6 np205 d60/sterling10.25
OBA, 36" hummer tires, some other stuff
2003 F350 Supercab shortbed FX4 6.0 PSD
  #8 (permalink)
Old 07-03-2007, 09:35 PM
meloncholy
I dont remember how the truck sat. I stripped it last summer. You have blocks or rear packs on your truck? Im looking into using this lift and i want to replace the rear blocks with spring packs so i need to find out for sure.
  #9 (permalink)
Old 07-03-2007, 09:39 PM
meloncholy
Ok i got another clue. It has daystar drop radius arm brackets iunno if thatll help figure it out.
  #10 (permalink)
Old 07-04-2007, 09:40 AM
dixiemudder04's Avatar
dixiemudder04 is starting off with a positive reputation.
i have 4'" susp 3" body and i can clear 38.5's with flex. I dont get the kind of flex with the 35's i had on it, but it will flex alittle. Just a sugguestion Take the weight off the suspension. mesure the coils. 19-1/8" for 4" and 6" coils are about 21".
  #11 (permalink)
Old 07-04-2007, 10:52 AM
meloncholy
Ok the coils are out of the truck ill measure them sometime today
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
