fuel Pressure - Ford Truck Enthusiasts Forums
fuel Pressure
Old 07-02-2007, 02:44 PM
Flea's Avatar
Flea Flea is offline
Flea is starting off with a positive reputation.
fuel Pressure
Hello, I am new to this forum.
I usually watch the OBS '94-'97 PSD forum.
I just switched over to WVO and I am having problems with fuel pressure.
When on WVO my truck coughs and chokes after a bit of time of being on it.
When on diesel it will run but when you put it under a load it will strain a bit.
I can also hear clicking and my pressure with a tire gauge is 37 psi at the schrader valve.
My plan is to clean out the FPR and see how it did. I just replaced the stock fuel filter and my big filter to a 2 micron filter which is filtering my veggie.
thanks,
Fletch
Old 07-02-2007, 06:18 PM
mongo75's Avatar
mongo75 mongo75 is offline
mongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to allmongo75 is a name known to all
How about your fuel pump- how many miles do you have on it- I'm not sure if 37 psi os enough to run the engine at higher rpms. Also, how well are you filtering you wvo before you put it in your tank?
Old 07-02-2007, 09:47 PM
250turbo 250turbo is offline
250turbo is starting off with a positive reputation.
should run 55 to 75 psi
Old 07-02-2007, 09:54 PM
Flea's Avatar
I have 102K miles on it. I am going to check fuel restriction on the fuel lines, Veggie and Dino. I also have a Racor filter with 2 micron capability. I am running the Golden Fuel Systems Nomad system.
Yea, I heard that 37psi wasn't enough.
I am going to check to make sure that their isn't a restriction on the lines then I am going to replace the fuel pump.
Any other ideas?
Flea
Old 07-02-2007, 10:10 PM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
Get a secondary pump as a lift pump.
Old 07-02-2007, 10:26 PM
Flea's Avatar
Permantely or temp? Where can I get a electric pump that is reliable and okay for the system?
Fletch
Old 07-03-2007, 01:13 AM
mongo75's Avatar
I know some guys are using a VW (I think Jetta) pump, but I'll have no such nonsense on my truck (no offense kwik hehe) I am assuming any pump capable of supplying at least 20 psi would be a good prepump- you just gotta get one with enough volume to keep up with the stock pump.
If I'm wrong on this one, someone please let me know...
Old 07-04-2007, 10:10 AM
Flea's Avatar
Well the stock pump has been changed and all is well now. I am back to burning veggie. I just wonder if it was coincidience that the stock pump went out a week after burning veggie?
If you don't think it is then what should I do to prevent this from happening again besides filtering which I do already. I have an electric pump pushing from the veggie tank.
Old 07-04-2007, 03:25 PM
mongo75's Avatar
Flea- I'm not familiar with the nomad system, but I can say that the stock lift pump is not designed to handle the additional strain of the thicker viscosity oil when you throw wvo through it, no matter how many pre-pumps you use. A pre-pump will only prolong the inevitable. In your case, your lift pump if stock, is already 11 years old, kinda on it's last leg. You need to do a search for a FASS WVO pump. I think the cheapest I've seen it online was for about $300, which is up to $200 CHEAPER than some wvo websites.
Old 07-06-2007, 11:34 PM
Ive lost my electric pump about a month after veggie. I didnt do it right and I did some other bad things. Heating and thinning is the issue.
Old 07-07-2007, 12:58 AM
Flea's Avatar
Well you want to heat and thin the veggie. That is why you want to lower the viscosity of the veggie oil.
Turns out it was time for my lift pump to go and actually was already going but the veggie helped me diagnose it quicker. I would have been left stranded on the road.
Tightwad Mod, WVO, do I need a FPR? JRogersOU 1994.5 - 1997 7.3L Power Stroke Diesel 2 08-17-2014 12:00 AM
water in my wvo? onthemoveactivist Bio-diesel, Propane & Alternative Diesel Engine Fuels 4 01-13-2014 01:42 AM
Regulated WVO system with built in default? Hotwheelbill Bio-diesel, Propane & Alternative Diesel Engine Fuels 3 05-29-2006 06:08 PM
WVO - the best idea parkland Bio-diesel, Propane & Alternative Diesel Engine Fuels 17 03-27-2006 04:02 PM
WVO Conversion myjack Bio-diesel, Propane & Alternative Diesel Engine Fuels 1 03-14-2005 07:07 PM
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
