Comp cams 5.4 camshafts?
Old 07-02-2007, 11:06 AM
armynavyguy's Avatar
armynavyguy
armynavyguy is offline
Anybody install Comp cams 5.4 camshafts on their truck? I'm curious about the power increase because comp now makes a camshaft for the V10 but they are just the cores. You have to tell them the lift and duration and so forth. I figured if any of you guys had these cams installed on your 5.4 and were happy with the results that the V10 would respond even better. Thanks
Old 07-04-2007, 11:11 PM
DM-03_6.0's Avatar
DM-03_6.0
DM-03_6.0 is offline
this info would be nice as i am also looking into some cams too
Old 07-06-2007, 11:44 AM
Machinator's Avatar
Machinator
Machinator is offline
TTT for a good question, someone make this a sticky please.
Old 07-06-2007, 12:45 PM
Johnny Langton's Avatar
Johnny Langton
Johnny Langton is offline
Unless you're going to change the intake manifold-you're wasting time and will actually hurt the power and torque output of the engine by changing cams to something with more duration.
JL
Old 07-06-2007, 09:27 PM
Machinator's Avatar
Machinator
JL
I have stated before that Reichard Racing will make 2 adapter plates and you can use either a bullet or regular p.i intake from a mustang gt. Either of these intakes can flow a good amount of air and will help the 5.4 benefit from a good set of ported heads and a cam set up for towing/hauling. I wouldnt want more duration at all because that would steal low end torque, I woud go with a bit more lift and mabe a 116 lsa.
Old 07-06-2007, 11:07 PM
DM-03_6.0's Avatar
DM-03_6.0
good stuff thanks! do you have a link for any of these?
Old 07-07-2007, 04:20 PM
ford390gashog's Avatar
ford390gashog
ford390gashog is offline
Summit racing sells the comp cams for this and they are not blanks. You pay 539.00 for the cams, 189.00 for the bee hive springs and you also need to get the pcm recalibrated. You can expect to gain 36-41 hp and 38-50 FT pounds of torque according to comp cams. This would be a good upgrade if you planned on putting a blower on it but by itself is not a very cost effective upgrade.
Old 07-07-2007, 06:07 PM
Johnny Langton
Those numbers are at the crank on a dyno setup engine,and they ARE NOT using a Truck intake manifold. I've got the 270AH cams in my Tbird,and it's a 10.7:1CR built engine with ported heads,bullitt intake,headers,etc,etc,etc. I only picked up about 20 hp peak,and 15-20 ft-lbs. I've got a 4000 rpm stall speed converter in the car,and it could use 200-300 more rpms of stall, speed to make it launch best-if I put this in a truck-it'd be a pig with any kind of torque converter setup for towing,and especially if you're gonna use that terribly restrictive truck intake.
JL
Old 07-07-2007, 11:12 PM
ford390gashog
JL,
The cams were installed using a truck intake. I assume you are talking about the cams for the old 2v 4.6 and 5.4 engines. I was talking about the brand new 3v 5.4 cam sets comp has out now. The 6.8 cams are set to launch in Oct of this year.
Old 07-08-2007, 03:51 AM
Johnny Langton
JL,
For a 3V,that's about right. The original poster was asking about his '01 model-which is a 2V.
JL
Old 07-08-2007, 04:01 AM
phil6608's Avatar
phil6608
phil6608 is offline
JL
With a set of Patriot ported heads and cams I made 38 RWHP on the dyno.
That was with no blower and a stock 5.4 2V intake manifold.
It wasn't quit worth the 2000 dollars I spent! lol
RustyRatRod
Ford Truck Parts for Sale
05-06-2016 01:20 AM
BigBlocker0248
01-16-2016 02:39 PM
bruno2
44
10-17-2015 09:02 PM
makuloco2000
2004 - 2008 F150
09-07-2015 04:23 PM
Reid Krabill
2004 - 2008 F150
08-10-2015 09:40 AM
Quick Reply: Comp cams 5.4 camshafts?
