Hybrid Oil Filter - Worst Ever Design - Ford Truck Enthusiasts Forums
Escape & Escape Hybrid Ford Escape, Ford Escape Hybrid, Mercury Mariner, Mazda Tribute
Old 07-02-2007, 11:38 AM
bhenders bhenders is offline
bhenders is starting off with a positive reputation.
Angry Hybrid Oil Filter - Worst Ever Design
Cautionary Note - 07 Mercury Mariner Hybrid - Worst Every Oil Filter Design
Note that the large O-ring for the Hybrid oil filter must be fitted into a "land" in the filter housing. It should not go all the way to the bottom of the housing, as this will pinch the O-ring and could result in a "latent" leak.
Since the molded plastic oil filters have totally proven themselves, one has to wonder why Ford had to go back to the "cartridge" type of filter that was common in the post WWII vehicles?
Truly a Worst Ever design.
Old 07-02-2007, 05:23 PM
GatorJ GatorJ is offline
GatorJ is starting off with a positive reputation.
From an environmental viewpoint, perhaps they generate less landfill waste?
Old 07-03-2007, 07:45 AM
Nitramjr's Avatar
Nitramjr Nitramjr is offline
Nitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant futureNitramjr has a brilliant future
I have talked online with many Escape Hybrid owners and you are the first owner I have heard complain about the design. Most of us really like the fact that all you change is the filter element and you can actually see the filter when you remove it for changing. I buy the Motorcraft filter kit online (element and both o-rings) for about $4 each.
As for the o-rings, you really can't be serious about putting the big one on incorrectly, are you? The "land" is pretty large and obvious and to be honest, I don't see how it would be possible to put it on any other way BUT correctly...especially if you took the old one off and paid even slight attention to what you were doing.
As for this being the worst design ever, I don't think it comes anywhere even close to being bad design. The filter housing is placed toward the front of the vehicle for easy access, points straight down for minimum spillage and even has a drain plug for the filter housing to further reduce any chance of making a mess. I have done 9 or 10 oil changes in my two hybrid Escapes and am very pleased with how easy and clean the job is. A 13 mm wrench, 4.5 qts of 5w-20 and a drain pan. Don't even need a filter wrench.
If you want to see bad design, look at the placement of the filter on a '97 F250 5.8W - it is impossible to remove the filter without getting oil all over the frame.
Old 07-04-2007, 10:09 AM
Heck, even changing the filter on a V-6 Escape can get pretyy messy.
Old 07-04-2007, 11:02 AM
Nitramjr's Avatar
Quote:
I forgot about that - I only had my V-6 Escape long enough for a couple oil changes.
I hate when the filter is mounted on the side of the engine since I like to pre-oil the filter before installing it. When it is straight down it is so much easier and cleaner.
Old 07-29-2007, 02:42 PM
chaseface84 chaseface84 is offline
chaseface84 is starting off with a positive reputation.
where do you get your filters from for only 4 bucks?
Old 07-29-2007, 07:30 PM
Nitramjr's Avatar
from these folks.....I believe they are a sponsor here...
http://www.discountfordpartsaty2kford.com/
Buy a bunch at a time and the shipping cost per filter is negligible.
Old 07-30-2007, 12:53 AM
thanks, looks like they raised their price a little but still a heck of a lot cheaper than other places ive looked
Oil Filter Standpipe O-Ring daddykitty 6.0L Power Stroke Diesel 2 03-01-2013 07:27 PM
Hot auto transmission oil smell Capt Skup 6.4L Power Stroke Diesel 2 10-18-2011 08:40 AM
Oil Filter Housing O-Ring Part # ? AndeyHall 6.0L Power Stroke Diesel 4 09-27-2010 09:17 PM
New Hybrid Cap/Filter combo? MoyockPowerstroke 6.0L Power Stroke Diesel 22 02-19-2009 10:10 PM
Any D.I.Y. Hybrid Oil Changers? Nitramjr Escape & Escape Hybrid 4 05-15-2006 07:10 AM
Tags
2007, 2009, change, changeing, changing, escape, filter, ford, housing, hybrid, hybridoil, oil, remove, replace, specifications
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
