Go Back   Ford Truck Enthusiasts Forums > Misc. > Brakes, Steering, Suspension, Tires, & Wheels
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Brakes, Steering, Suspension, Tires, & Wheels Click Here
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 07-02-2007, 06:33 AM
truckman01 is starting off with a positive reputation.
bleeding brakes
I took the front right caliper off my 94 f150 to replace the rotor and after I got it all back together the brakes felt spongy. Now I don't think the piston in the caliper really moved so why would it feel like I got air in there. Am I supposed to compress the piston back or something? How would air get in like this anyway? I have done this a few times before on my ranger and the brakes worked fine after. If I do have to bleed do I only have to bleed at this wheel?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-02-2007, 10:32 AM
aurgathor is gaining momentum as a positive member of FTE.
Just bleed that one first to see if it helps. If not, do all four.
Even if the brakes feel right, bleeding them periodically (I do it every other year or so) is a good practice.
  #3 (permalink)
Old 07-22-2007, 04:25 AM
bradshaw6243's Avatar
Up, Up and Away
bradshaw6243 has a great reputation on FTE.bradshaw6243 has a great reputation on FTE.bradshaw6243 has a great reputation on FTE.bradshaw6243 has a great reputation on FTE.bradshaw6243 has a great reputation on FTE.bradshaw6243 has a great reputation on FTE.
Hey truckman, even if the master cylinder piston did not move you have definitely gotten air in the system if you disconnected any line. Only a few bubbles can cause sponginess. Your best bet to get good pedal back is to bleed the entire system starting with the furthest wheel from the master cylinder first. Right rear, left rear, right front, then left front. I bet this solves your problem.
__________________
Jim
1995 F-150 351 Auto. Ext.Cab SWB
"Watch out where the Huskies go, and don't you eat that yellow snow" Frank Zappa
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
