Rear window seal. - Ford Truck Enthusiasts Forums
Rear window seal.
Old 07-01-2007, 08:12 PM
crw2 crw2 is offline
crw2 is starting off with a positive reputation.
Question Rear window seal.
Hello all,
I have a 2000 f-150 ext-cab lariat. I have a sliding rear window with water coming into the cab around the seal. I can visually see that the seal is not seated properly.My ?? is this. Is changing the seal somthing that I want to, or can do on a saturday afternoon ,with no specialty tool needed? Am i better off just taking it somewhere and paying to have it fixed? anyone know what i can expect to pay? (I'm talking about the seal that goes around the entire rear window assembly under the plastic trim)
Thanks.
Old 07-01-2007, 10:33 PM
jjlogue3's Avatar
jjlogue3 jjlogue3 is offline
jjlogue3 has a good reputation on FTE.jjlogue3 has a good reputation on FTE.
I had this same problem on my 99 and took it to the body shop to have a new seal put in it and it cost less than $100.
Old 07-01-2007, 10:57 PM
Thank you very much,sounds like a deal to me.
Old 07-02-2007, 12:35 AM
steve(ill)'s Avatar
steve(ill) steve(ill) is offline
steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.steve(ill) has a great reputation on FTE.
common problem to leak. i bought a 12 ounce black RTV tube at the hardware store, filled the crack in solid between the plastic trim and the roof panel. NEVER leak again.
Old 07-03-2007, 08:44 AM
stang3O2 stang3O2 is offline
stang3O2 is starting off with a positive reputation.
Black RTV silicone here as well!!! Many of these leaks come from the third brake light, I would also caulk around the edge of the light!
Old 07-03-2007, 02:44 PM
ATC Crazy's Avatar
ATC Crazy ATC Crazy is offline
ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.ATC Crazy has a very good reputation on FTE.
The origional owner of my truck took it to the dealership and replaced the whole rear window frame. Well...It still leaks today when I wash it.
RTV is next on my list
Old 05-27-2008, 08:00 AM
hutseh hutseh is offline
hutseh is starting off with a positive reputation.
Anybody know what comes with the replacement seal kit (3L3Z-1542052-AA) for TSB 04-2-2, leaking rear window? Is it the seal around the whole unit or just the slide tracks that hold the movable section?
Thanks.
Old 05-27-2008, 01:09 PM
BigPoppa67 BigPoppa67 is offline
BigPoppa67 is starting off with a positive reputation.
i replaced my own seal with butyl rope from AZ for about 8 bucks. gotta remove the headliner, side panels around windows, and back seat. then remove 2 dozen nuts and cut old seal to loosen it. razor blade off the old seal and clean up both surfaces. laid down the butyl. with help, i placed the window back in and EVENLY tightened it back down. while i had the beauty trim off i painted it,too.
Old 05-27-2008, 01:20 PM
NumberDummy's Avatar
NumberDummy NumberDummy is offline
Ford Parts Specialist
NumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputationNumberDummy has a superb reputation
Quote:
Originally Posted by hutseh View Post
Anybody know what comes with the replacement seal kit (3L3Z-1542052-AA) for TSB 04-2-2, leaking rear window? Is it the seal around the whole unit or just the slide tracks that hold the movable section?Thanks.
3L3Z1542052AA .. "Kit, Back Window Glass" is what FTE sponsor ftepartsguy.com's website sez.
The MSRP is $43.30.
You might contact him and ask what the kit contains. ftepartsguy is Ed Olson @ Parr Ford in Bremerton, WA.
btw: Type Ford part numbers into websites without the hyphens, otherwise you'll get this: No parts found.
Old 05-29-2008, 11:34 AM
Rear window seal
Tanks for da info.
Old 05-29-2008, 07:35 PM
sheetsd66 sheetsd66 is offline
sheetsd66 is starting off with a positive reputation.
The back window glass kit is the seals between the panes of glass. It won't fix the leak you're talking about here. Ford used to make a rubber seal to fix the leaks caused by cracked/broken window frames, but they were crap. I'm not sure if you can even buy it any more. Ford also sells a "Foam seal" for the back glass but all it is is a butyl seal with a foam core. Go to the local parts store and get a roll of butyl tape and a tube of black RTV. Seal the frame to the cab with the butyl and seal the cracks with the silicon.
Old 05-30-2008, 09:04 AM
jwal jwal is offline
jwal is starting off with a positive reputation.
i had the same problem on my 99. i ended up just replacing the window (mt slider latch was broken) and put in a solid. i used silicone to seal the window from the inside and really gooped up the new window before installing.
99 F150 supercab rear sliding window leak FordLou 1997 - 2003 F150 4 11-27-2016 05:21 PM
Sliding rear window seals - 95 Regular Cab Glenn54 1987 - 1996 F150 & Larger F-Series Trucks 12 10-19-2016 12:49 AM
Fix Your Super Duty Water Leaks Under Pressure 1999 to 2016 Super Duty 2 03-21-2014 02:59 PM
Rear Window Seal cparks 1957 - 1960 F100 & Larger F-Series Trucks 15 10-06-2013 05:03 AM
Replace rear window!? ericford1984 1980 - 1986 Bullnose F100, F150 & Larger F-Series Trucks 9 01-21-2012 05:07 PM
Tags
150, 2002, brake, f150, ford, glass, kit, light, rear, replacing, seal, seals, sliding, truck, window
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
