If you're asking why go through the IC, it is becuase the intake air get's REAL hot when it's compressed by the turbo, which it would stay (hot) if you eliminated the IC. If you're thinking that the intake charge picks up more heat (going through 8-10 of tubing) than is drawn out by the IC then you are mistaken.
__________________
2000 Boss Gator 4x4 Kenne Bell
Max HP: Classified
Max Torque: Classified
0-60: Classified
Best 60': Classified
Best 1/4: Classified
Do it right, do it once (perhaps twice if you try to run more than 14psi on stock rods, or if you don't read the instructions properly).
