A REAL cold air box...and CHEAP!
Well now that I wouldn't be the one reviving the tread from the depths, I haven't looked at my setup lately, but any input as to how this would work with the dual tube intakes? Such as the one on my '90 302. I wouldn't mind building one but I have a hard time imagining dual cone filters.
I know, but I would have to keep them small enough to fit together, but that would still end up with a larger box than I'd like.
All you need is the cone filter adapter ring to your TB size.. (Stock pickup is 75mm), and a conical filter. In my case, I use the AFE oiless filter now.
Ah, guess I never looked under the hood of any of the MAF 302s around here. Suppose I might as well pull the whole MAF if I find one. Now I'm going to need to do some searching to find out what all I'll need for the 302 AOD MAF conversion. I know, but I would have to keep them small enough to fit together, but that would still end up with a larger box than I'd like.
Mr. M-I'm waiting on more funds....I've seemed to have ran into a dry cow so to speak.....
Basically, the idear I had, was a LOOONNNNNGGGGG CAI.....And wrap it with the thermal cloth to help keep the air colder, and denser...
BUT.....
I've been reading up on the WAI (Warm Air Intake), and it seems the whole fuel atomization occurs, when the air is WARM.....Seems the colder air/fuel mixture tends to stick to the sides of the intake manifold....
Whereas the warmer air (Which we all know warmer air expands) spreads the air/fuel molecules around, thus giving a more evenly mixed A/F mixture....
My idea may actually spawn into a C/WAI both....Using a electric choke of sorts, in reverse....As the engine warms up, CLOSE the choke, utilizing the warmer air for better MPG's.....And when the ambient air in the engine bay cools, have it OPEN....For more torque, such as in a pulling scenario.....Idk....Maybe even more advanced, maybe a MANUAL choke would be better....It'd give the option of MPG/Torque & Horsepower....
Just a thought to chew on....
BUT.....
It's the AOD that's controlled by the TV cable attached to the TB. I have no idea if there's any vacuum, I asume it's the same as being operated by the cable. It is a '90 so it's pre-AOD-E as that came in '91 I think.
The intakes that I like best are those that are sealed off from the engine but open to the outside so I really like the option of being able to open the front to catch the air coming through the grill.
GBuckert-The TV cable will adjust the shift points in the tranny also....Didn't know if ya already knew that....And if its the AOD, like in my 1991 Crown Vic, no, there aren't any vacuum lines...It's got the TV cable, and a MECHANICAL shifter linkage...Hence the need for the Ford AOD Kickdown Linkage on the carbs....
Also...If the tranny gets to shifting bad/randomly/sluggish, check the TV cable bushing....They tend to wear out...Thus causing issues...
#28
Never heard about the bushing, I'll check it out. I adjusted the cable and changed fluid/filter to clear most everything up with the tranny, but that bushing probably needs looked at too. Thanks!
#29
IIRC, the TV bushing is around the kickdown linkage....Somewhere...LOL
Also, IIRC, its a brass/Copper outfit......So yea....150k plus miles, its gonna wear some....
And as far as the 302 computer;
If its a ELECTRONIC tranny (E4OD/AODE) it will need the computer from whatever it came out of.....A mechanical, its just that, a mechanical linkage from the throttle.....It tells the tranny to shift when a certain POINT is reached, not a certain rpm, like in the electronic shifting units...
Thats the reason the place where a tranny shifts, is STILL called shift points...lol....
#30
If you switch to mass air , you need a MA computer , sence you have an AOD a mustang computer would work good , or a computer from a MA truck with a stick , and if you enclose your air filter in a box it needs a good sized inlet to let the air in , it can't be air tight , and a good size box.....Lew
