Easy headlight question
07-01-2007, 02:59 PM
on
On the 3 prong plug, which terminal is which?
I believe high beam is opposite ground and low beam is the one in the middle, correct?
07-02-2007, 11:58 PM
on
I think you're right but it only works right one way. Keep experimenting. Look at the other headlight. It may be grounded near the light.
07-03-2007, 12:01 AM
on
hi again. I'm not sure if it matters but some of those old ones were positive ground. Watch for that.
07-03-2007, 07:04 AM
on
With the vehicle connector plug facing you like this I _ I
Left is ground Center is low Right is high
Paul
