Go Back   Ford Truck Enthusiasts Forums > Performance, Engines & Troubleshooting > Other Ford Engines > 4 Cylinder Engines
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
  #1 (permalink)
Old 06-30-2007, 07:51 PM
98range 98range is offline
Garage is empty, add now
98range is starting off with a positive reputation.
1998 2.5L timing belt change
Have a 1998 2.5L that I just did a timing belt change. All the marks lined up after turning over the motor 2 turns. When driven it has alot of pinging under acceleration in all gears. Is this a non-interference motor?
Can I move the cam sprocket either one tooth to the right or left and see if the pinging goes away? I'm stumped why it pings!
Tags
2000, 25, belt, changing, cyl, engine, firing, ford, installation, liter, litre, marks, order, replacement, timing
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
