Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Competition Diesel racing, sleds, dynos, power tuning and max performance.
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-30-2007, 07:42 PM
cabinetmaker00's Avatar
cabinetmaker00 is starting off with a positive reputation.
installing egr cooler upipe with block off plate
Well I had to put my truck back to stock right now ,as the weather here in so cal has been getting hot so has my truck yesterday it overheated on me
and of course my coolant was a gallon orr so low since I've been blowing it out my res so my next step is to get this http://discountpowerparts.com/catalo...oducts_id=2212
My question is can you do this without pulling the cab ,I've done the manifolds before on my previous truck but would like some input from those that have done this to there truck .
__________________
2006 f250 cc,sb,4x4,6.0.
zoodad,sc1805, 4 in lbss exhaust.
tint.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 07-01-2007, 07:21 AM
npccpartsman's Avatar
npccpartsman is gaining momentum as a positive member of FTE.npccpartsman is gaining momentum as a positive member of FTE.
It's a little tight, but very easily accomplished without pulling the cab. Get yourself a 10mm and a 13mm ratcheting flex wrench also. Makes the job lots easer if you have a set of those to work on a 6.0L. Pulled the turbo and cleaned it while doing this, but it's not absolutely necessary to do. Spray all the exhaust pipe bolts with penetrating oil as long beforehand as you can stand not driving your truck.
__________________
I BLEED RAZORBACK RED
  #3 (permalink)
Old 07-01-2007, 05:09 PM
cool man I only got 12,000 miles on her so all the bolts are in good shape ,just got to pull the inner fender liner and get up in there with some flex wrenches . I cant wait to see the difference without the stock piece ,should have better spool up and a lot lower coolant temps .
__________________
tint.
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
