Rear shock absorber mounting stud on 1948 F2
I am needing to replace the rear shock absorber mounting studs (#18193) on a 1948 F2. It looks like the stud presses on to the spring seat. I would like to replace the stud on the vehicle without disassembling the springs.
Any ideas on how I can remove the old stud and install a new one? If I drill it out will I be able to hammer a new stud in or will I need a press? Has any body done this and who did you purchase the stud from
Thanks
Frank
Thanks
Frank
Received 1,344 Likes
on
on
I hear you on not wanting to remove the bracket but I don`t know what else to suggest.....Except to try drilling it out and welding a proper sized bolt in, it depends on what you have on hand and available to use. Once you have it out you can take it to a welding shop for repairs. I doubt trying to hammer in a replacement will work out.
I bought one from Sacramento Vintage for my F1. I'd think the F2 is the same here.
The one I got 7 years ago didn't fit quite right. The shank was slightly undersized so I re-used the old one.
Sorry, this doesn't help much. Just what I've found out there. Bet you could find something local - NAPA, Suspension shop, etc.......
bryanmartin
08-16-2013 07:16 PM
Jodell
03-24-2009 01:39 PM
rcav8or
18
06-04-2008 04:18 PM
satx77stepside
12-21-2003 10:36 PM
