Go Back   Ford Truck Enthusiasts Forums > Older, Classic and Antique Trucks > 1947 and Older Ford Trucks
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-30-2007, 02:46 AM
hedtrpr is starting off with a positive reputation.
Do I need a cooler on my TH400?
Hi,
I have a GM350 with a TH400 tranny inmy '38 Pickup. Do I need to have a cooler? I do not haul anything but me and my gal and no racing.
Thanks, DM
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-30-2007, 02:50 AM
pfogle's Avatar
Village Idiot
pfogle is gaining momentum as a positive member of FTE.
No you don't need a cooler as long as your radiator has the cooler built in. I think I'd scrap the chebby motor and slide a 302 or 351w in it with an AOD transmission. You'd get a LOT better mileage and very similar performance.
__________________
1992 E150, 351, 1 ton E4OD (RIP)
Courtesy of my WIFE: "Why do they call it 'scruff' when it's more like mini-daggers?"
  #3 (permalink)
Old 06-30-2007, 03:00 AM
Its a bit late about the motor and tranny. Both totally rebuilt and mounted. I'd heard though that the coolers were not needed at all, secondary or in radiator if you are not using it as anything more than transportation. Wrong?
Thanks, DM
  #4 (permalink)
Old 06-30-2007, 03:08 AM
ford390gashog's Avatar
ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.ford390gashog has a very good reputation on FTE.
Yeah way wrong. Any hydraulic unit without proper cooling will overheat and start destroying all the soft components. How do you have it set up now? Please tell me you don't have both cooler lines plugged. If you have the lines plugged say good bye to the transmisson the return line is used to lubricate the output shaft bushings on its way back to the pan.
  #5 (permalink)
Old 06-30-2007, 09:03 AM
frty7ford's Avatar
frty7ford is starting off with a positive reputation.
someone help him find a real engine for that truck
__________________
Jim
Elko, Nevada
1965 F100 240 I6 3speed overdrive
1965 F250 390/auto Camper Special
1947 1T flathead 8/4Speed
1977 F250 460/autoS/C Trailer Special
1976 F250 460/auto Camper Special
  #6 (permalink)
Old 06-30-2007, 11:21 AM
Jeez you guys... I'm sorry about the motor and tranny! But in reality if they had not come with this half finished project, I'd have done as you suggest. I know this will be probably the first Ford with GM components in its......... Anyway, no I do not have those tubes plugged. I do have a cooler on the tranny, just didn't know how essential it was. Thanks for the infor. I'll cool er!
DM
  #7 (permalink)
Old 06-30-2007, 12:24 PM
3Mike6 is gaining momentum as a positive member of FTE.3Mike6 is gaining momentum as a positive member of FTE.
Don't fret about the SBC, it's way less headache in your truck than fitting in a SBF engine.
If you have an external cooler only, make sure it's located in front of the radiator so the fan will draw air through it...but it's best to plumb through the correct radiator to keep the tranny fuid temps down.
  #8 (permalink)
Old 07-05-2007, 01:21 PM
tomoto is starting off with a positive reputation.
its call hot rodding
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
