Go Back   Ford Truck Enthusiasts Forums > Regional Chapters > Western Region > Washington Chapter
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Washington Chapter Washington Chapter
Join Chapter, Leader: Snowbunny
  #1 (permalink)
Old 06-29-2007, 02:13 PM
MARTYSTOWRIG's Avatar
MARTYSTOWRIG MARTYSTOWRIG is offline
Garage is empty, add now
MARTYSTOWRIG is gaining momentum as a positive member of FTE.MARTYSTOWRIG is gaining momentum as a positive member of FTE.
I need some steel studs
I am finally redoing my trailer floor and I think I will replace rotton wood with steel studs instead of the original 2x4's
I need them cheap$$ or free. I will take rems too.
Marty 206-423-5803
__________________
Pimpin Gas Piper
99 F250 EX Cab, 4X4,
Sirius Radio,Blackbird GPS/NAV
Kargo Master Pro II Rack
Cobra 75, Lariat trim, BFG A/T T/A
original Crown Society Member
  #2 (permalink)
Old 06-29-2007, 03:54 PM
Ford_Six's Avatar
Ford_Six Ford_Six is offline
1969 Ford F-250
Ford_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputationFord_Six has a superb reputation
Just a note, steel studs can't take the side load that 2x4s can, so if they're laying down supporting the floor, they will give out pretty quick. Best long term fix would be some 3.5x1.5x3/16" square tube, or C channel. Much stronger, a little more pricey, but will last a good long time.
__________________
Jared
Real trucks have the key on the left
FTE Guidelines
  #3 (permalink)
Old 06-30-2007, 01:19 AM
Quote:
These will be laying flat side vertical and I will weld lateral supports in betewwn them. I am not redoing the whole thing but I will make sure the ones I do put in are BETTER and STRONGER than wood. My brother in law is getting me some woven fiber material they wrap new buildings and houses in. It is kind of like tyvek but breathable. Allows moisture out but not in. I saw it at a home show once. Pricy though .40 per sq ft. 100' roll. He is getting me a rem thankfully for a 6 pack from a job they just finished.
Thanks for keeping me straight though Jared
__________________
Pimpin Gas Piper
  #4 (permalink)
Old 06-30-2007, 08:26 AM
RexB's Avatar
RexB RexB is offline
RexB is gaining momentum as a positive member of FTE.RexB is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by MARTYSTOWRIG
I am finally redoing my trailer floor and I think I will replace rotton wood with steel studs instead of the original 2x4's.
I need them cheap$$ or free. I will take rems too. Marty 206-423-5803
Steel prices are through the roof aren't they.
What are the size/dimensions that you are looking for cheap$ or free, and does mild steel work for ya'? If quantity is not too much, i have some flat and bar steel.
Locally, www.everettsteel.com and www.metalshorts.com often has remnants in bins for lower price than others.
  #5 (permalink)
Old 06-30-2007, 01:59 PM
REX,
I think mild steel is not quite what I need. Thanks though.
I still need to be able to screw it inplace with existing wood and light gauge steel. I am unsure of sizing yet I will know Sunday when I get er opened up.
I hav alot of buddies in the construction trades and HOPE they are going to be able to get me a couple of framing studs. I think they are idealin size strength and workability.
I am thinking this through and will not have a good BOM until I am actually finished..... But that is how my projects usually go.
__________________
Pimpin Gas Piper
  #6 (permalink)
Old 06-30-2007, 05:45 PM
Placermike's Avatar
Placermike Placermike is offline
Placermike has a very good reputation on FTE.Placermike has a very good reputation on FTE.Placermike has a very good reputation on FTE.Placermike has a very good reputation on FTE.
I don't think you want to use framing studs for a floor. They are great for walls, once the drywall is applied, but not designed to be load bearing. McKenzie could bend one faster than a 2x4.
__________________
"I wear my own kind of hat" (Merle Haggard)
EClampus Vitus Major WM Downie 1849
  #7 (permalink)
Old 06-30-2007, 11:33 PM
Mr. M's Avatar
Mr. M Mr. M is offline
Mr. M is starting off with a positive reputation.
No...but aluminum sure has gone up. 75-80% in the past year.
__________________
94 F150 4x4 XLT-"Teal Mobile"-Fresh 306 9.5:1, built e7's 1.94in/1.60ex, custom cam, long tubes, OEM MAF, 4.10's, 4" lift, E4OD 225 rwhp - Dynojet- SAE
BMW E46 M3 -
"Track Rat"-TopasBlue on Cinnamon -3.2L 6spd,11.5:1 CR, JVT Headers/Borla Exhaust, RE pullies, ESS tune, 4.10's, GroundControl Coils, UUC Sways, Rotora 4 piston F&R BBK, 171 mph (closed track) 313 rwhp Dynojet-SAE- 12.88 107.4 mph
  #8 (permalink)
Old 07-01-2007, 09:14 AM
RexB's Avatar
Quote:
No on steel? Where you buying steel stock in-state at the same prices? I'm shopping there.
And on the skyrocketing aluminum, I flatten out old alum boat trailer fenders and use it, new stock quantity isn't even affordable for the common guy anymore.
  #9 (permalink)
Old 07-01-2007, 10:45 AM
Mr. M's Avatar
Cd'A Metals in Wenatchee. I believe there is one is Spokane as well.
__________________
BMW E46 M3 -
  #10 (permalink)
Old 07-01-2007, 01:13 PM
RexB's Avatar
http://www.ford-trucks.com/forums/62...ml#post4888705
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
