Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > 2004 - 2008 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
2004 - 2008 F150
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-29-2007, 02:25 PM
damianromero is starting off with a positive reputation.
2005 inner door panel removal
how do i removal the inner door panel on my 2005 f150...thanks
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-29-2007, 03:26 PM
black04lariat's Avatar
black04lariat is starting off with a positive reputation.
front door, rear door...reg cab, super cab, super crew....?
try the search function
what are you trying to do?
  #3 (permalink)
Old 06-29-2007, 03:55 PM
sorry, so i can mount my tweeters....front inner door panel, reg cab 2005 f150 stx
  #4 (permalink)
Old 06-29-2007, 03:57 PM
Courtesy of NASSTY
Remove the little cover plate behind the interior door handle w/ small flatblade screwdriver.
Remove 2 screws behind the coverplate.
Remove armrest/window switch panel cover.Start from the front of armrest/switch panel and lift the cover off the armrest,then unplug window and doorlock switches.
Remove the screw from switch panel hole w/10mm socket.
Remove speaker grill,pry off with small flat blade screwdriver.
Remove 4 screws to the speaker,remove the speaker and unplug.
Remove the bottom 2 white plastic things the speaker screws attatch to.
Remove 2 screws at the bottom of the door panel.Lift door panel up and away from door while finagleing the interior doorhandle through the hole in the door panel.First you have to unsnap and push the handle in through the door panel,then when removing the doorpanel the handle has to go out through the panel.
  #5 (permalink)
Old 06-29-2007, 03:58 PM
if you have manual windows you will need to remove teh window crank too most likely
  #6 (permalink)
Old 06-29-2007, 04:50 PM
soxfan81's Avatar
soxfan81 is starting off with a positive reputation.
Quote:
You really need to learn to search i just covered removing the door panel and removing the door handle 5 days ago. It's probally on the second page of threads.
  #7 (permalink)
Old 06-21-2008, 07:00 PM
ordychief's Avatar
ordychief is starting off with a positive reputation.
Thanks to black04lariet for the info on how to remove the door panel. Sometimes you have to tug on things to get them loose. I was hesitant to lift too hard on the window and door lock panel to get it off. Everything went great. New drivers side elect mirror thanks in part to my carport post!!!!!!!!
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
