4.6L Oil Capacity with Filter please! - Ford Truck Enthusiasts Forums
Old 06-29-2007, 12:46 PM
61UniB100's Avatar
61UniB100 61UniB100 is offline
61UniB100 is starting off with a positive reputation.
Just picked up a F-150 SuperCrew with the 4.6L and I need to change the oil but need to know the oil capacity with filter change. I'm new to these style F-150's. Thanks!
Old 06-29-2007, 01:02 PM
skilife17's Avatar
skilife17 skilife17 is offline
skilife17 is starting off with a positive reputation.
Quote:
Should be 6 quarts with filter. Double check your owners manual to be sure.
Old 06-29-2007, 01:11 PM
61UniB100's Avatar
Thanks! the reason i posted it up was because I just picked the truck up and it doesn't have a owners manual.
Old 06-29-2007, 01:16 PM
skilife17's Avatar
You can download your manual off the intetnet. I just can't remember the site.
Old 06-29-2007, 02:11 PM
KingRanchMan02's Avatar
KingRanchMan02 KingRanchMan02 is offline
KingRanchMan02 is gaining momentum as a positive member of FTE.KingRanchMan02 is gaining momentum as a positive member of FTE.
Try here. https://www.fleet.ford.com/maintenance/maintenance.asp Then click on owners manuals on the left hand side.
Old 06-29-2007, 03:21 PM
Big Bad Big Bad is offline
Big Bad has a good reputation on FTE.Big Bad has a good reputation on FTE.
The owner's manual says 6 quarts. However, 6 quarts with a filter change will only even bring the oil level about half-way up the cross hatch on the dipstick after it's been primed/started.
The truck will take about 6.5 quarts for proper fill level with a filter change.
That's the case on my 2001 Supercrew (4.6L) and on numerous others I've changed the oil on.
Old 06-29-2007, 03:22 PM
61UniB100's Avatar
Thanks Big Bad! I will go ahead and get seven quarts then to be safe. Thanks everyone
Old 06-29-2007, 07:37 PM
galaxie641 galaxie641 is offline
galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.galaxie641 has a very good reputation on FTE.
Yep, it is at least 6.5, mine takes 7 because I also have the remote mount filter that has a good 6-10 feet of hose to fill up. Always if in doubt on a gas engine put 5qts in and start checking the dipstick until you get it to the right level.
Old 06-29-2007, 10:03 PM
B-61 Bulldog B-61 Bulldog is offline
B-61 Bulldog is starting off with a positive reputation.
Ditto what big bad said this is the case on my 01' 4.6 Also
later
Bulldog
Old 07-15-2007, 01:38 PM
sidneymac sidneymac is offline
sidneymac is starting off with a positive reputation.
oil
on your dip stick the oil level should be between the min and max marque,you should put it at max
Old 07-16-2007, 08:39 AM
ranger88a ranger88a is offline
ranger88a is starting off with a positive reputation.
Dipstick length can vary slightly, therefore, anywhere in the crosshatched area is full. Adding more than the recommended amount 6qt. is overfilling which can be as bad as underfilling.
Old 07-16-2007, 01:56 PM
1. 6 qts is slightly underfilled.
2. Modulars have a deep skirt block that sets the crank deep into the block, running even a extra full quart on the mod motor engines will not have the detrimental effects to the same degree it has on a shallow skirt engine.
3. Underfilling a Modular engine is not a good thing, and far worse than slightly overfilling. Modulars like to push alot of oil into the cam/rocker area to help lube those overhead cam journals, that can cause the pump to suck the pan dry.
4. 6.5 quarts is the optimum amount to run in a 4.6L F150.
Old 07-16-2007, 02:47 PM
ajbeiler ajbeiler is offline
ajbeiler is starting off with a positive reputation.
6 quarts is fine maybe a little more depending on the filter.
Old 07-16-2007, 03:45 PM
4.6L 2V Triton F-150/250 (under 8500 GVW only) 6.0 qt. filter fl 820 s. From the Ford manual! 1. 6.0 qt is the optimum capacity. 2. The pan isn't near as deep as an older design. 3. What? the oil is restricted to the heads and as long as I have worked on these things I've never seen the oil pan sucked dry and it all end up in the heads.
Old 07-16-2007, 05:51 PM
Quote:
1. And 6.0 quarts is adequate, not optimum.
2. The pan is plenty deep. The crank is raised into the block, overfilling a Modular (6.5 quarts is NOT overfilled, BTW) is not as easy as overfilling a Windsor. Plenty of open track racers will add an additional quart for an event to prevent the pan from being sucked dry on Modulars. Modulars also do not gain power by draining a quart like the Windsors do either. Deep skirt block...
3. If you've never seen a Modular that has sucked the pan dry you haven't been around very many Modulars. The Modulars pump ALOT of oil in the heads, with sustained RPM the the oil will pump into the head faster than the oil returns drain in back into the pan. If the pan is underfilled the problem is magnified.
Trailer Towing Capacity awonboys 2004 - 2008 F150 9 12-29-2013 10:52 PM
F-150 5.4L oil capacity? ghiaman46 1997 - 2003 F150 12 05-29-2011 05:20 PM
4.6l oil filter threads silent1tomb 2004 - 2008 F150 5 07-23-2007 12:04 PM
98 4.6L dipstick wrong.. Anyone else? JH6 Modular V8 (4.6L, 5.4L) 7 12-23-2006 12:03 AM
1995 5.0L Engine Oil Capacity DTrain Small Block V8 (221, 260, 289, 5.0/302, 5.8/351W) 4 01-20-2004 06:02 PM
Tags
05, 08, 2000, 2003, 2009, 2010, 46, 46l, capacity, explorer, f150, filter, ford, oil, specs
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
