Go Back   Ford Truck Enthusiasts Forums > Diesel > Bio-diesel, Propane & Alternative Diesel Engine Fuels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Bio-diesel, Propane & Alternative Diesel Engine Fuels SPONSORED BY:
  #1 (permalink)
Old 06-29-2007, 11:09 AM
blieux1's Avatar
blieux1 blieux1 is offline
Garage is empty, add now
blieux1 is starting off with a positive reputation.
Magnesol Use
What is the ratio of magnesol to bio, how long do i mix and what size of filters do i need. I have a 100gal. processor and want to build a condesor for it. What size tubing and how long or big should i make it.
  #2 (permalink)
Old 06-29-2007, 09:55 PM
fabmandelux's Avatar
fabmandelux fabmandelux is online now
1935 Ford pickup
fabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputationfabmandelux has a superb reputation
Quote:
Bio with the methanol still in it will require 2% by weight. If you recover the methanol first and filter out the soap, you only need 1%. Mix for 30 min, with MECHANICAL MIXING ONLY! Then filter with a 5 micron bag filter, then a 1 micron "absolute" filter bag.
What form of Methanol recovery are you going to use? Heat or Vacume?
__________________
Oregon Chapter Leader My friends call me Don.
"I always keep a supply of stimulants handy in case I see a snake, which I also keep handy" WC Fields
  #3 (permalink)
Old 06-29-2007, 11:37 PM
blieux1's Avatar
Since this is my first time I am going with the heat first. I do have a nice industrial vaccume pump for when I get a better understanding of what I'm doing. You say mechanical mixing, why not a pump like the 1'' water pumps. Magnesol by weight, what does a gal. bio weigh?
  #4 (permalink)
Old 06-29-2007, 11:42 PM
kennedyford's Avatar
kennedyford kennedyford is offline
kennedyford is starting off with a positive reputation.
Pump mixing sheers the magnesol receptors and grinds it to an even finite powder and you end up with junk. Bio is 7.2 or 7.4 lbs per gallon. 7.2 x gallon of bio mix x .02 = magnesol lbs.
__________________
585,000+ miles on original engine. Goldie 00 F-350
  #5 (permalink)
Old 06-29-2007, 11:49 PM
blieux1's Avatar
I really don't have to remove the methanol first, the magnesol will take care of it too?
  #6 (permalink)
Old 06-30-2007, 06:41 PM
1935 Ford pickup
Yes, the Magnesol will remove EVERYTHING nasty...........BUT.....If you recover the methanol first, the soap will fall out of suspension, and can be filtered out. Plus you cut the cost of making the bio by using the recovered Methanol in your next batch And you also need only half as much Magnesol!
__________________
Tags
befroe, biodiesel, diesel, filter, filtering, forum, heat, magnasol, magnelsol, magnesol, magnseol, mix, press, ratio, removal
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
