centering the steering wheel
hi all.... well, after getting my truck back from the shop for a camber kit/alignment, and a 650.00 bill, i still need my steering wheel centered a little. they did fix it some, but i think it still needs a touch more. so, on the rack and pinion setup, dont you just have to adjust the tie rod ends? my wheel is slightly to the right when going straight. so, cant i just thread the driver side in, and the pass side out by the same amount? is that how they do it in the shop? also, my wheel feels like there is a little bit of play in it. is there anyway to adjust that as well? thanks for all your help.
Alignment
Even though you've just had the truck aligned, go back to the shop and let them know that the steering wheel isn't level. That is part of the alignment. You have to turn the sleeves for the tie rod ends to do the wheel.
The steering wheel should have been locked down, straight and level when it was aligned. I do this for a living...........
Bob
Bob
Is that something that can be done at home? Mine is barely off center and I am about 4hrs away from the place that did my alignment? I noticed it when I picked it up but had other arrangements and didnt get time to make it back to the place that did the alignment.
Bob
Bob
as for the wheel again, is it safe to assume that i could try it in my driveway so long as i run each side the same amount, as long as one goes in and one goes out? i figured i could go one revolution at a time and see what happens.
ok, here is an update.... i adjusted the tie rod ends, and of course one turn on each is too much, in fact it was closer before i made the adjustment. so what i am wondering now, is there any way to adjust the rack and pinion position on the truck? if the whole thing could move over towards the pass side by maybe 1/16- 1/8 of an inch, i bet it would be just enough to re-center the wheel. thanks again !!
I wouldn't move that rack for anything. After the alignment was done, that person should have driven the truck and checked the steering wheel to see how it looked, and how the truck drove. Specially after putting in a caster camber kit...........
If at all possible, see if you can get the tie rod sleves back where they where. then maybe go a half turn the other direction. When you did this you may have made you're toe setting wrong and wear tires...............
spin the inner shaft, not...
Spin the inner shaft that the tie rod mounts to.
You don't have to remove the ball joint to adjust the toe angle. Just loosen the jamb nut on the ball joint and spin the tube that the ball joint is threaded to. There is a special ball joint on the other end of that tube, so it will spin. You can do any amount of adjustment you want; 1/2 turn, 1/4 turn, etc.
Loosen the nut, mark the tube for future reference, spin some and drive it, adjust as needed.
good luck -jim
good luck -jim
