Go Back   Ford Truck Enthusiasts Forums > Small Chassis Trucks > Bronco II
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-28-2007, 11:41 PM
Blueovalguy88 is starting off with a positive reputation.
Flat towing a B2
Is it possible for me to flat tow my B2? It has the push button transfer case so there is no neutral option, but it has a standard transmission. Do I just take it out of gear and go, or is this not an option on my model B2. If not what can I do to change it to be able? Thanks in advance.
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-29-2007, 01:28 AM
Help I M Stuck is starting off with a positive reputation.
straight up, honest, easiest, headache free way is to pull the front and rear drive shafts. Then there is no questions to which is the right way and wrong way. I've seen this question asked before and everyone has a different idea. PULL THE DRIVESHAFTS and be done!
__________________
-Jeff
86 Bronco II 4inch suspesnion lift, 3inch body, 35x12.50x15 BFT AT/s and 4:10gears.
05 F250 Superduty Diesel--tows the BII to the trails
  #3 (permalink)
Old 06-29-2007, 09:55 AM
kernel-panic's Avatar
kernel-panic is starting off with a positive reputation.
I have to agree with Jeff on this one, mainly because your only option for putting the t-case in neutral is to pull the shift motor. It'd be easier to just pull at least the rear driveshaft, but if you have automatic hubs, it's best to pull both. Mine is all manual, so I usually leave the hubs unlocked and put everything in neutral.
__________________
1987 Bronco II XLT 2.9L V-6 5-Spd 4x4
'xplorer coils & leafs, MT/R 30x9.50s, 2 1/2" cat-back
1995 Nissan D21 Hardbody 2.4L I-4 5-Spd 2WD
MSD, K&N air filter, Taylor wires, Pacesetter header & 2 1/2" exhaust
2004 Toyota Tacoma Xtracab SR5 3.4L V-6 5-Spd 4WD
(K&N air, all else is bone stock!)
  #4 (permalink)
Old 06-30-2007, 10:05 AM
azjay is starting off with a positive reputation.
mine is an '86 EB, auto/od, it is set up with a drive shaft slip yoke, pull a choke cable thingy under driver's seat and it disconnects the drive shaft, about $1500 installed. it has been towed thousands of miles this way. the alternative, would be to convert the transfer case to a manual shift. the elec.shift is same transfer case as man.shift, just need to change the shift method.
  #5 (permalink)
Old 06-30-2007, 10:15 AM
fordthug's Avatar
fordthug is starting off with a positive reputation.
ya i would try to tow bar it or anything like that if theres no neutral position becasue my dad acidentally left his in gear and burned up the t case and tranny but it might work if you leave it in 2h but not sure
__________________
Joe Trimmell
Kansas Chapter photographer
My Bronco gallery
Friends DON'T let Friends Drive Chevy's
I'd rather eat worms than drive a Chevy
  #6 (permalink)
Old 06-30-2007, 11:03 AM
Looks like I'm stuck with a trailer queen if I want to take it anywhere to go offroading. I cant afford to make any serious mods to it, and it's just to easy to pull it on the trailer as opposed to pulling shafts. Thanks for the info guys.
  #7 (permalink)
Old 06-30-2007, 12:49 PM
That's what mine is..stays on the trailer when not on the trails. With 4 inch suspension and 3 inch body and 35.12.50x15 inch tires it drives ok under 40mph..but after that probably cuz it's been steadily wheeled every weekend for 3yrs.
__________________
-Jeff
  #8 (permalink)
Old 07-03-2007, 01:19 AM
Offroadin is starting off with a positive reputation.
Smile
My b2 has front locking hubs and when I use a tow bar to tow mine I unlock my front hubs and just take the bolts out of the differencial 4 bolts and then I just tie the driveshaft up out of the way.
hopes this helps!
  #9 (permalink)
Old 07-03-2007, 08:30 PM
White Noise is starting off with a positive reputation.
Hey I'm glad I took a look at this thread, because I'm moving to North Carolina from Alabama and I was thinking about towing my B2 with a tow dolly, but now I'm certain I will use the car hauler. Thankd for being there everyone!
  #10 (permalink)
Old 07-26-2007, 01:51 PM
5.0B2 is starting off with a positive reputation.
The BorgWarner 1350 transfer case doesn't have a rear pump. Drag it very far and the bearings will seize - turning your BII into an anchor. My retired boss tried it behind his motor home on a snowbird trip from Montana to Arizona.
  #11 (permalink)
Old 07-29-2007, 08:00 AM
I beg to differ, 5.0: http://therangerstation.com/tech_lib...sferCases.html. Not to mention I flat towed my '87 BII at an average of 55-60 mph over the course of several days from Seattle-area, Washington to Virginia Beach, Virginia (That's like 3000-3500 miles). I think your boss' BII's transfer case probably had bad bearings and/or a bad pump and that is why it seized. The 1350 and 1354 cases are almost identical, and I believe the main difference between the two is the front output yokes... but I could be wrong. *shrug*
__________________
  #12 (permalink)
Old 03-25-2008, 01:42 PM
Update- Kernel is absolutely correct. Just finished perusing my shop manual. the B/W 1350 has an oiling pump run by the rear output shaft. anchor it in neutral and tow to your heart's content!
__________________
1965 Falcon Ranchero hiPo 289 9"
1979 Lincoln Versailles 351W 4v
1984 BII 5.0FI 4R70W B/W 1356 d35 & 8.8/disks
1997 Explorer Sport 4.0 OHV
  #13 (permalink)
Old 04-03-2008, 10:00 AM
Sponsor
Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.Bear River has a very good reputation on FTE.
The only problem with this method isthat it takes up more space and costs a bit more, but I prefer having a trailer to save wear and tear on the tow vehicle. Trailer parts are much cheaper to replace in general, why should i put wear on the wheel bearings and differentials when I'm not even driving it. In most states you must also put an emergency brake on your towalong, but a trailer can be equipped with brakes for a lot cheaper.
__________________
My Rides
1994 Ford Aerostar 4.0L AWD extended
175,000 miles
Fullblown 50 series catback system
590 watt sound system
AFE ProDryS filter
1990 Mazda B2600i
505,000 miles
Custom exhaust with BearCats high flow converter and a straight through muffler
Custom high velocity intake with AFE ProDryS filter
http://www.bearriverconverters.com
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
