Go Back   Ford Truck Enthusiasts Forums > Performance, Engines and Troubleshooting > Modular V10 (6.8l)
New! Use your Facebook, Google, AIM & Yahoo accounts to securely log into this site, click logo to login
Modular V10 (6.8l) SPONSORED BY:
Is F-150 Still King?
  #1 (permalink)
Old 06-28-2007, 03:53 PM
scm281 scm281 is offline
scm281 is starting off with a positive reputation.
Exclamation V10 Shoot out plug
Hello,
I have a 02 F250 with a v10 and the other day it blasted out the number 5 plug. The truck has 96,xxx miles on it and the warranty is over. I took it to Ford and they said even with 1000's of people having the same issue this is not a recall item and it will cost $5,248.00 to replace the head because it can't be repaired. This being my work truck every day I need to get it fixed right away but feel I'm getting taken out by Ford with no dinner first if you know what I mean! I found this guy at www.blownoutsparkplug.com/ and he seem to be highly recommended by people. It cost $4500.00 less to have him do the repair. I was wondering if anyone might have used him? This is one of the best sites out here and I apologize if I mist a forum about this already. Thanks for your help!
  #2 (permalink)
Old 06-28-2007, 04:08 PM
metalman1320 metalman1320 is offline
metalman1320 is starting off with a positive reputation.
Also check out the Timesert repair. That's what alot of guys have used. You can do it yourself for a few hundred bucks if I remember correctly.
As far as that guy your referring to, I think their are a few people on here that have used him, and they seem to be pleased.
If you do a search for timesert or blown spark plug, you'll find lots of info.......
__________________
04 F350 XLT 4X4 SRW SC SB V10, factory 4.30's, 2.5" leveling kit, Bilstein's all the way around, 315/75R16 Toyo M/T's, BSEG's every time I plant my right foot.
Quote from EnviroCon: "A bad spring is kind of like porn, in that it's sometimes hard to define, but I'll know it if I see it."
  #3 (permalink)
Old 06-28-2007, 04:50 PM
saskdiesel saskdiesel is offline
saskdiesel is starting off with a positive reputation.
I would do the timesert if my truck spat a plug.
I am curious to whether the plugs were changed at some time earlier.
  #4 (permalink)
Old 06-28-2007, 07:12 PM
Thanks for the replies,
It looks like it may never been done. I would try myself I just dont have the time. I hate having somone else do the work but I have deadlines I have to meet. Just can't win.
  #5 (permalink)
Old 06-29-2007, 05:00 AM
Move over I'm coming Move over I'm coming is offline
Move over I'm coming is gaining momentum as a positive member of FTE.
Smile Save the $5000 spend $250
I will have to agree with the Keensert repair. I work in a maintainence garage and have used the Keensert to repair 2 5.4L heads. It took a couple of hours and they have held up well. Half of the time is rigging up the shop vac to suck up the shavings. the 5.4L has just -2 cyl than the 6.8L.
  #6 (permalink)
Old 06-29-2007, 07:11 AM
FortyFords's Avatar
FortyFords FortyFords is offline
FortyFords is gaining momentum as a positive member of FTE.
Most of us have used Timesert and have had great success with them.
Takes a couple hrs .
Rich
__________________
" All levers like real trucks should be!" "Cool enough for me!"
" BSEG CLUB" 10 Strokin and 4 Smokin!
  #7 (permalink)
Old 06-29-2007, 10:11 AM
Krewat's Avatar
Krewat Krewat is online now
Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future Krewat has a brilliant future
While you're poking around in there, check the heater core hoses and make sure they aren't leaking down onto that #5 COP.
Do the insert repair. Much cheaper
__________________
- art k. - Moderator for the Superduty, V10, and FE forums
'01 F250SD SC SB XLT V10 4x4 auto 3.73 Warn hubs Volant CAI, eBay headers and y-pipe - 5-star custom tunes on SCT X3
'97 Cougar XR7 30th Anniv Edition 4.6L
'74 F250 Highboy FE390 deceased!
I've been wrong before, I'll be wrong again. Just wait and see.
  #8 (permalink)
Old 06-29-2007, 11:51 AM
michaelmueller michaelmueller is offline
michaelmueller is starting off with a positive reputation.
I posted a while back about my plug blowout and I repaired it myself for $30 with a plug repair kit from auto zone, it is just like the timesert kit except it comes with just 3 or 4 different size inserts, 10k and still going strong.
One thing you need to know with this kit though, the tap it comes with has a 3/4" head on it that needs to be ground down to fit in a spark plug socket so it can fit down into the plug hole.
__________________
smile with a black tooth grin.
02 F-250 supercab sb 4x4 Lariat bright red V-10
  #9 (permalink)
Old 06-29-2007, 03:36 PM
Thanks again for all the advice. I'll let you know how it go's!
  #10 (permalink)
Old 07-01-2007, 07:12 PM
captchas's Avatar
captchas captchas is offline
captchas has a very good reputation on FTE. captchas has a very good reputation on FTE. captchas has a very good reputation on FTE.
timesert man only way to fly for a in truck repair. the others are just copycats of the real thing. and while your doing one do all ten and never worry again
  #11 (permalink)
Old 07-01-2007, 07:13 PM
captchas's Avatar
Quote:
44 years in dealer shops and as a factory feild tech. i've never heard of that one
  #12 (permalink)
Old 07-01-2007, 10:56 PM
Monsta's Avatar
Monsta Monsta is offline
Sit. Stay.
2005 Ford Excursion
Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of Monsta has much to be proud of
It took you an hour to rig up a shop vac?!? Not familiar with duct tape?
__________________
Ken
Cats; nasty creatures...
  #13 (permalink)
Old 07-01-2007, 11:24 PM
Quote:
OOPS I ment Timesert. I've got them in the Keensert drawer 1/8" to 3/4".
As we get older the first thing that goes is our hair. What was that second thing....
!@#%^&*(&^$%^& - - - I was suggesting that the repair was fairly easy ( IMO ) and yes, the EX has a roll of duct tape in the toolbox.
I also work as a Field Maintenance Technician + ASE cert.
  #14 (permalink)
Old 07-02-2007, 01:37 AM
Monsta's Avatar
Sit. Stay.
2005 Ford Excursion
Glad to see you have a sense of humor! Comes in handy here.
__________________
Ken
  #15 (permalink)
Old 07-02-2007, 09:43 AM
captchas's Avatar
hair ? wait till you hit 60 like me! you loose more then the hair. and it just might be some very important that stops working ,
Tags
54l , plug , shooting
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Guidelines - Contact Us - Ford Truck Enthusiasts - Archive - Top
Powered by: vBulletin | Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
