Go Back   Ford Truck Enthusiasts Forums > Misc. > Towing, Trailers & 5th Wheels
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Towing, Trailers & 5th Wheels SPONSORED BY:
  #1 (permalink)
Old 06-28-2007, 11:12 AM
jonnysteals jonnysteals is offline
Garage is empty, add now
jonnysteals is starting off with a positive reputation.
Talking Travel trailer to car hauler
i ahve the oppurtunity to pick up a 25-30 foot long travel trailer. This is not a mobile home but a travel trailer that is emnt to be trailered around constantly. I want to convert it to a car hauler to haul around a full size pick up. I read alot about mobile homes that they arent good trailers but I believe that a travel trailer would be a better candidate because it has to be built stronger because it is constantly being towed. The trailer have dual axels, and I am presuming that they have brakes on the axels. Would this traielr be able to tow a 6-7 thousand pund truck. would any modifications need to be made to the frame. I plan on putting a 2x6 decking on it also. Any suggestions would be very, very helpful Jon
  #2 (permalink)
Old 06-28-2007, 11:30 AM
Spamjohnson's Avatar
Spamjohnson Spamjohnson is offline
Spamjohnson is starting off with a positive reputation.
I would think some of the trailer strength would come from the TT shell also, you would loose some of that strength.
How about building a frame, and just using the axles.
__________________
Sam Johnson
Minnesota
99.0XLTPSD6SpdCCLB4X4
02TDIJettaWagon
  #3 (permalink)
Old 06-28-2007, 12:13 PM
Dogwood36322's Avatar
Dogwood36322 Dogwood36322 is offline
Dogwood36322 is starting off with a positive reputation.
Frame rails will probably be narrower than required therefore needing to add support to widen. Trailer frame will probably carry the weight and most travel trailers have electric brakes. Also ramp angle might be excessive without dove-tailing the rear of the frame. Lot of work involved in my opinion. Hope you are getting it donated to you.
__________________
Jim
Army Aviation
2011 F350 CC Dually, Lariat Ultimate B&W Turnover Ball, B&W Companion fifth wheel
2008 Sandpiper 285RGD 35 ft fiver
2012 Expedition
1998 Mustang
  #4 (permalink)
Old 06-28-2007, 10:35 PM
79driver's Avatar
79driver 79driver is offline
79driver is starting off with a positive reputation.
Not trying to be a smartelec, but why not just sell the TT and buy a car hauler? Be easier, safer and maybe less money involved
__________________
'79 Ford F-150, Ranger Lariat, 4x4, 460
'07 Ford F-250, Lariat Outlaw, 4x4, 6.0 PSD
'69 Ford Bronco, 351, Fully restored
'71 AM General Deuce-and-a-half
  #5 (permalink)
Old 06-29-2007, 01:16 AM
Powerstroker_18 Powerstroker_18 is offline
Powerstroker_18 is starting off with a positive reputation.
In my semi-professional opinion as an RV Service tech I would say it's a bad idea, travel trailers aren't made to carry that kind of weight, A whole travel trailer frame and that size would probably weigh no more than 6500 lbs including the frame, and all the weight of the trailer itself is distributed evenly. The frame design is all wrong. Even though it's a tandem axle trailer and there should be brakes on both axles the position of the axles is more forward than a car trailer, which will cause a really bad tow.
Tags
car, convert, convertcamptrailertocarhauler, converted, converting, design, frame, hauler, home, mobile, pick, rv, trailer, travel, truck, widen
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
