1991 Ranger Ignition Switch Removal - Ford Truck Enthusiasts Forums
Ranger & B-Series All Ford Ranger and Mazda B-Series models
Old 06-28-2007, 11:15 AM
medicpg's Avatar
medicpg medicpg is offline
medicpg is starting off with a positive reputation.
I went to Start my truck last nite and the switch was stuck. It would not budge. Obviously it needs to be replaced. Anyone know how to remove it from the column?
Old 06-28-2007, 11:25 AM
pgw85706 pgw85706 is offline
pgw85706 is starting off with a positive reputation.
Maybe the steering lock is bound and not allowing the key to rotate? Does yours have the thumb lever to release the switch to rotate?
Old 06-28-2007, 11:28 AM
medicpg's Avatar
I forgot....I am at work now....It was midnite when we had the problem so I was a little punch drunk. My gut feeling is no
Old 06-28-2007, 01:28 PM
ranger1999 Bob's Avatar
ranger1999 Bob ranger1999 Bob is offline
ranger1999 Bob has a good reputation on FTE.ranger1999 Bob has a good reputation on FTE.ranger1999 Bob has a good reputation on FTE.
well if its like most of them you pop the steering wheel off and remove the turn signal unit and there is a clip or screw in there that holds the switch in. My advice tho is to make sure that it is the switch 99% of the time its something with the linkage that jams it up. If you really think its the switch try shooting some WD40 up the keyhole first to make sure the pins in the cylinder arent gunked up. Ive never done one on the ranger im basing it on my experiences with the old GM columns which ive repaired a ton of over the years for my old cab company and some of the older work trucks we had
Old 06-28-2007, 02:01 PM
wtroger wtroger is offline
wtroger is gaining momentum as a positive member of FTE.wtroger is gaining momentum as a positive member of FTE.
There is an issue with tab in the lock (where the key goes) that runs the I left the key in the ignition buzzer breaking off and jamming the lock so it will not turn. We use a dental pick to get these out. It is a common problem. you can look down in it with a light and see if the little brass sucker is in there. It can also be the linkage from the key to the switch but usually they just break (espescially with tilt wheel) and you can turn the lock forever and it desn't move the switch. I have not seen a switch itself jam I have seen them come apart and the vehicle not start or some accessories not work.
remove headlight switch 1973 F100 SeaCarr 1973 - 1979 F-100 & Larger F-Series Trucks 5 10-21-2013 03:16 PM
Multifunction Switch, and electronic flasher location BigBlueMacDaddy Electrical Systems/Wiring 7 08-04-2011 12:32 AM
Wiper switch removal Badmrscary 1961 - 1966 F-100 & Larger F-Series Trucks 4 02-15-2011 05:57 PM
Remove headlight switch ? HowieE Electrical Systems/Wiring 3 11-12-2009 12:07 AM
08 upfitter switch removal 94yj 1999 to 2016 Super Duty 28 12-03-2007 08:57 PM
Tags
1991, ford, ignition, located, lock, ranger, removal, replacement, switch
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
