9inch final drive ?’s
While this question is about an E-150, please consider this to be a F-150 since 351W - 3speed overdrive [4speed standard] E-150’s are extremely rare. [about 1 in a thousand vans made in 77 and 78 for they had to be ordered]
I have a stock 2 barrel carb on a healthy 351W.
I have purchased a 89 parts van with a 3.53 possi rear end that apears to work properly. While I currently have a non possi 3.53 in the van, I beleive that my 78 came with a 3 to 1 rear end new.
The first gear on my 3speed overdrive [4speed standard] seems to be too high for Portland Oregon [we have a lot of hills on my side of town]. Also when I am driving on the freeway with a half a ton or so of building materials, Overdrive is useless and I use third.
Did ford make the 3speed overdrive with a varity of gear ratios?
Is there another ford manual trans, with a compatable linkage on the side that I should consider?
What rear end ratios have those of you with an F-150 been using with this engine and trans?
Many thanks,
David
Many thanks,
David
flainn
41
07-05-2011 07:50 PM
davidh
07-30-2007 05:15 AM
78f250lj
01-22-2003 06:57 PM
