351w vs 360 fe
Old 07-15-2007, 10:00 PM
mattri's Avatar
mattri
mattri is offline
351w vs 360 fe
Have a 69 f100 2wd with a 360 fe. Truck is going to be a daily driver, no heavy towing. Looking to either build up the 360 a little, maybe swap in 390 crank rods, 4v intake and carb, mild cam, headers and elec ignition.
Or swap in a 351w, same mild build, stock heads.
Not looking for huge power numbers, just want something that will get out of its own way, be a good driver and not kill me on gas.
Looking at the windsor because it's close in cubes, lighter and can bolt a 5spd up pretty easy. Any suggestions, ideas? Thank, Matt.
Old 07-16-2007, 12:05 AM
Blurry94's Avatar
Blurry94
Blurry94 is offline
You will find a wider variety of aftermarket parts and accessories with a 351w.
Old 07-16-2007, 12:18 AM
Mtthwvn73's Avatar
Mtthwvn73
Mtthwvn73 is offline
I'd say find you a 390. You already have the tranny (An FE bellhousing won't bolt up to a smallblock). You'll be able to spend the money on the motor, and not have to worry about messing with a different tranny, probably having to change driveshafts, different mounts, ect. You can keep the tranny, and still make a good bit of power. Rebuild a 390 and get the power package from Edelbrock, that should really get that truck moving.
Matt
Old 07-16-2007, 08:34 AM
mattri's Avatar
mattri
mattri is offline
Thanks for the replies. I deffinetly want to swap trannys, looking for a 5spd, not the granny 4spd I have now.
Old 07-16-2007, 03:59 PM
HemiEater's Avatar
HemiEater
HemiEater is offline
then go with the 351W other wise do a 390 like mtthwvn73 said.
Old 07-16-2007, 06:55 PM
Red69's Avatar
Red69
Red69 is offline
The 351W will take a different set of engine mount towers and you will have trouble finding an exhaust that works in that model truck.
Old 07-16-2007, 11:26 PM
LxMan1's Avatar
LxMan1
LxMan1 is offline
No problem with exhaust when using manifolds. Any exhaust shop can make a system from the manifolds back. They did on my 63 F100 with a 351W. You will need 302 motor mount towers. Pretty common on those trucks.
Old 07-17-2007, 06:04 PM
Red69's Avatar
Red69
Red69 is offline
I have a set of stock manifolds and the outlet is about 2 inches away and pointing straight at the firewall when I tried them on my 69..
nkf
12-06-2016 08:51 PM
Mister_King
01-11-2015 10:03 PM
raven3
30
07-03-2014 07:27 PM
darkpurp1e
03-10-2012 08:18 PM
popeye69
07-30-2003 11:32 AM
Quick Reply: 351w vs 360 fe
