2001 F150 Fuel Pump Inertia Switch - Ford Truck Enthusiasts Forums
Old 06-27-2007, 07:45 PM
geckocub69 geckocub69 is offline
geckocub69 is starting off with a positive reputation.
I have loacted the Fuel Pump Inertia Switch, however, how do i nkow if it it needing the be "reset"? It is currently pushed all the way into the recessed button whole.
Old 06-27-2007, 08:23 PM
lariat97's Avatar
lariat97 lariat97 is offline
lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.lariat97 has a spectacular reputation.
If it needed to be reset you would know. Your truck wouldn't run. If I remember right it pops out when its tripped.
Old 06-27-2007, 08:29 PM
The truck does not run....
2001 Ford F150 v8 Auto Wont start but will crank?
I have replaced the fuel pump relays, the fuel filter and all fuses. I do not know how to check the Fuel Pump Inertia Switch but i have located it. I also know it might be the original fuel pump, but I am trying to get around that one. Any help would be greatly appreciated.
Also, the tank is full, and the truck was left under a carport for the past two days while it rained and was running fine before then.
Old 06-27-2007, 08:50 PM
lariat97's Avatar
Push the switch & try to crank the truck. I went out & looked at mine. Its on with the button all the way down. You could pull the fuel line at the filter & turn the key on to test the fuel pump. Be sure you put the line in a can to catch the fuel. You have to jar the truck real hard to set off the inertia switch. Are you sure you are getting fire?
Old 06-27-2007, 09:02 PM
how can i tell if i am getting fire? I dont have any tools and am not very good with cars.
Old 06-28-2007, 07:55 PM
lariat97's Avatar
The only way I know to check is to pull a coil & see if its firing. You could pull one of the coils & hold it near the block while you turn the motor over. It should spark. There must be a way to test it with a multi meter. Hopefully someone with more experience than me will post up a answer for you.
Old 06-28-2007, 10:47 PM
streethealer's Avatar
streethealer streethealer is offline
streethealer is starting off with a positive reputation.
Will it start with a shot of ether (starting fluid)? If it will, then it's getting fire and not fuel. Just open the air intake at the filter, spray a shot of ether in and see if it will start. If it starts, I'm 99% sure it is a bad fuel pump. The reset switch is "rarely" a problem. Good Luck
Old 06-28-2007, 10:52 PM
I am not sure where the air intake is to do a shot?
Old 06-28-2007, 11:51 PM
On the drivers side of the vehicle in front on my 1999 F-150. Mine is big and round and I can't miss it. Yours may be square I'm not sure, never been under the hood on a 2001 model, but in any case, it is where your air filter is located. just open the air filter box and spray a shot of ether in there(about a half second burst) and try to crank it really quick. As I stated earlier, if it starts, it's getting fire and not fuel. I suspect the pump since you have changed everything else. Good Luck
Old 07-01-2007, 05:46 PM
burninfordrubber burninfordrubber is offline
burninfordrubber is starting off with a positive reputation.
If the bed bolts will come out fairly easy. I would lift the bed. You will need a couple of buddies to help you. just lift bed and move back enough to get to the top of tank. Be carefull of the wire harness for brake lights under rear bumper I just unplug them them you have no worries. 99% sure its your fuel pump myself. good luck....
1996 f150 no fuel phat rat 1987 - 1996 F150 & Larger F-Series Trucks 19 09-13-2009 11:00 PM
97 Windstar fuel pump inertia switch? smackme Aerostar 3 02-21-2007 02:09 AM
Fuel Pump Inertia Switch!!! scaryracer33 Aerostar 4 07-23-2006 11:08 PM
inertia fuel switch cbjr61 1987 - 1996 F150 & Larger F-Series Trucks 5 08-03-2005 02:43 PM
Inertia switch location crank Aerostar 5 11-06-2003 02:15 AM
Tags
01, 2001, bumper, f150, ford, fuel, ineretia, inerser, inertia, location, pump, rear, reset, shutoff, switch, truck
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
