Have you registered for your free membership? If not, click here now to register!
Join Our Site - Its free, quick and easy!
Click Here to join.   Click Here for more information
Users Chatting None
Go Back   Ford Truck Enthusiasts Forums > Newer Light Duty Trucks > The 2009 F150
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
The 2009 F150 Discuss the new 2009 Ford F150
Is F-150 Still King?
LinkBack Thread Tools
  #31 (permalink)
Old 06-30-2007, 11:43 AM
385seriesHemi is gaining momentum as a positive member of FTE.
Whatever people say, whatever people think, inline engine style period is built tougher than any V type engine. I have a F150 with a 300 - 6 and have driven a F350 dually dump truck with a 300 - 6 plenty of times. Which i might add that truck has about 225,000 on it and still goes with a FULL bed load of concrete we tear out on jobs we do. Also the 5.0 302 FI engines have a few more problems than the straight sixes like detination on #7 & 8 cylinders. The 302 will just be a car engine thats all its worth to me. I deal with mainly 460s n stuff but I will choose the Inline six anyday for pulling, especially with the 4bbl carb setup.
__________________
Gearhead for life slammin' iron & chrome right to the bone!
1992 F150 300-6ci
1976 Cadillac Coupe Deville 500ci
1998 Dodge Ram 4x4 318ci
1970 Chevy Nova SS 360ci
  #32 (permalink)
Old 07-01-2007, 11:01 AM
Crazy001's Avatar
Crazy001 is starting off with a positive reputation.
You're right, of course, for the reasons mentioned above. My question is how relevent is it.....
Any modern V6, and hell, for that matter even the not-so-modern 4.2, can last well past 200,000 miles in a half ton. Many who have that much endurance on a 4.2 have worked their truck, time after time. Why would Ford spend the money to lengthen the engine bay to squeeze an inline engine under the hood?
Add to that development costs on the new I6 motor, and you're spending lots more than Ford would want to on a base power plant on a base truck.
Better engine? Of course it is. But is it worth it?
But..then again...if you have room for the I6....you'd have room for the V10....
__________________
Tom,
Current truck - 2007 F150 Screw 4x4
Previous Fords:
2005 Mustang 4.0 auto
2003 F150 4x4 r/c auto
  #33 (permalink)
Old 07-01-2007, 11:55 AM
zbollman is starting off with a positive reputation.
I think the switch to an I6 would be solely for more torque to anyone hauling. A modernized I6 will put out just as much power as a V6, but so much more torque... But as you said, the question is whether Ford thinks it's worth the time and resources to modernize one or re-develope one.
Zach
  #34 (permalink)
Old 07-04-2007, 05:19 PM
woodbutcher05 is starting off with a positive reputation.
Talking
RE:Aluminum head for 300 I6.There IS one in development NOW.Should be out,baring delays later this year.Check on fordsix.com.
Leo
  #35 (permalink)
Old 07-04-2007, 07:10 PM
B's FX4's Avatar
B's FX4 is starting off with a positive reputation.
or it will be just a dog just like the 4.2 v6 is underpowered and slow and not great on gas but ford will promote its a diesel...for petes sake just make a bad ass diesel please
  #36 (permalink)
Old 07-04-2007, 08:23 PM
David85 is gaining momentum as a positive member of FTE.
Quote:
Leo
Sounds promising.
I'd settle for a cummins 3.9L turbo, like what ford offers in other markets for thier light trucks. Should be good for about 25mpg or better.
__________________
1986 F250HD Ex cab Fresh built up 6.9L diesel Lariat AC leather seats power everything w/full cluster, sterling rear 3.08LS gears, E4OD trans, ram intake ATS 088 turbo
1986 F150 Ex cab Lariat rollercam 5.0L on LPG AOD trans 3.55 gears 390 000Ks
  #37 (permalink)
Peter94's Avatar
Peter94 is gaining momentum as a positive member of FTE.
Quote:
Originally Posted by zbollman
I have never rode in V6 F150, I am just going by what people have said about the truck they have with them.
Well, hitting the gas pedal is kind of like stepping on a soggy marshmallow. . We had one for a work truck, all loaded down with tools and stuff. It would get you around in town, but on the highway, you had to really give it the berrys to avoid getting run over.
Hmmmm, my 300 could really use an aluminum head!
I swear there is nothing better than putting my truck in granny low and letting it wind out a little bit. Its probably my favorite sound in the world.
__________________
88 4x4 300 six, 5spd. granny 1st, reg cab 3.55
85 4x4 5.0L F-One Fiddy Reg Cab 3.55 With a Flatbed
^Now that its 21 years old, it can smoke and drink!^
  #38 (permalink)
Old 07-24-2007, 10:35 AM
joekiser is starting off with a positive reputation.
Back in the early 80's, the 300-six had about ten more ft-lbs than the 302. This was with a single barrel carb (as opposed to 2v on the 302) and restrictive manifolds that looked like friggin logs. Put on a 4bbl and EFI manifolds and that engine will pull anything. Classic-inlines.net is developing an aluminum head, and later on will release a turbo kit for the 4.9.
  #39 (permalink)
Old 07-24-2007, 12:16 PM
V8EXPLR is gaining momentum as a positive member of FTE.
Not sure if the V6 will be released in the 1st year model, but sounds like the V6 will be similar to this:
http://www.sema.org/Main/ArticleDeta...ontentID=57851
Of course if may not be pushing that kind of HP, cause then it'd be out doing some of the V8's.
__________________
Justin
2006 Ford F-150 SuperCrew XLT Chrome Edition
5.4L Flex-Fuel, 3.73LS, 18" Stock Rims, 18" BFG Rugged Trail T/A's, Trailer Tow Pkg
Sun/Moonroof, Fog Lamps, Ford Bedliner
Lund Headlight & Taillight Covers, Lund VentVisors
  #40 (permalink)
Old 07-24-2007, 01:56 PM
the_webers_inc's Avatar
A mostly quiet
the_webers_inc is starting off with a positive reputation.
The 3.5L/3.7L V6 should make a good introductory/base motor for the new F-150
In regards to an updated I6 -- all Ford would have to do is import the 4.0L DOHC I6 from down under (Australia) now that would be awesome
T. J.
__________________
06 F-150 XLT Scab, 6.5' Box, 5.4L, 4x4, 3.73LS
--Line-X
--TruXedo Original
--Nifty Catch-All Xtreme Floorliners
--2008 Telescoping Trailer Tow Mirrors
03 Saturn VUE SUV 2.2L Ecotec I4, 5spd - 23/29 mpg - The Commute Vehicle
95 F150 XLT 4x4 4.9L I6 5spd - Sold
89 F150 XLT 4x4 4.9L I6 4spd - Sold
91 F150 XLT 4x4 4.9L I6 5spd - Deceased
  #41 (permalink)
Old 07-24-2007, 02:26 PM
They should bring a lot more from austrailia than just the 4.0 I6...........
__________________
  #42 (permalink)
Old 07-24-2007, 02:44 PM
Quote:
I'll second that!
__________________
Justin
  #43 (permalink)
Old 07-24-2007, 04:12 PM
Fellers,I hate to tell ya,BUT Ford Austraila is CLOSING the engine plant that makes the inline engines in 2010.NO MORE inline engines.Forgot this.Check out the thread over at www.fordsix.com titled:Ford Austraila---Engine Plant Closing,in the Gasoline Alley section.
Leo
  #44 (permalink)
Old 07-24-2007, 04:23 PM
Leo
Heck, I'd take more than just the Inline motors Ford Australia produces. Those Focus's look really nice for a compact, and the Falcon XR8 with the 6spd kicks A$$, as well as the Ute version. Also a 4-door Ranger with a turbo diesel would be nice.
__________________
Justin
  #45 (permalink)
Old 07-24-2007, 06:46 PM
Quote:
Stop it, Stop it! I can't take it anymore!!
The Falcon Ute is something that could eat a mustang cobra for breakfast, and still tow a decent sized trailer (possibly both at the same time).
The Ranger is avalable with TWO seperate turbo diesel engines and can tow around 7000lbs worth of trailer (you can bet they push them harder)!!!!
(sigh) Why does our selection suck on this continent???
(end of rant, checks blood pressure)
__________________
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Terms of Use - Privacy Policy - JOBS
Ford-Trucks.com and Internet Brands, Inc. is not affiliated with the Ford Motor Company.
© 1997-2007 Internet Brands, Inc., Please see our Terms of Use / Privacy Policy
