lets see if this helps
the dia of your 265 tire is 31.56 x 3.14 (pie) gives you a circumfrance of 99in
and the 285 is 32.58 x 3.14 gives you 102in when you multiply the revs per mil
639 for the 265 and 659 for the 285 anyhow the 265 tire will have to travel an
extra 5 ft per mile so if you travel 100mi it will be an extra 500 ft and if i did this right
you will have to travel 1056 miles on the 265 to equal the same on the 285.
so for any math wiz's out there to confirm?
