B20 or B99??? Are there Advantages or Disadvantages? - Ford Truck Enthusiasts Forums
Old 06-27-2007, 11:15 AM
captaincook's Avatar
captaincook captaincook is offline
captaincook is starting off with a positive reputation.
Im going on my lunch to buy my very first tank of BIO. The place has B20 and B99. I dont know which one to use? Need some imput.
Old 06-27-2007, 11:19 AM
monsterbaby's Avatar
monsterbaby monsterbaby is offline
monsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputationmonsterbaby has a superb reputation
well depending on how full your tank is now would make some difference if this si the first time you have run bio. if you have over half a tank go ahead and fill up with the 99 but and this is just my personal opinion for the first few times you run it I would run less than 50% (thus the reason I said half a tank max) and would actually suggest running at or below 25% to let it clean out your fuel system before going straight bio, and keep a spare fuel filter with you. But after your sure or at least pretty sure the tank is cleaned up I really like running mine on 100% bio in the summer.
Old 06-27-2007, 11:22 AM
Its on empty. The light came on right as I was pulling into work this morning. So you would go with the B20?
Old 06-27-2007, 11:28 AM
yep for your first tank especially I would go with the B20 and be sure and stop and pickup a fuel filter just to have with you. After a few tanks then you could switch to the B99, like I said I like running at that level myself but even after not running bio all winter (can't get it locally and the way I am setup can't make it in the winter) I still start at B25 and work up to the B100 within about a month (and change my filter after a couple of weeks although it doesn't seem to plug anymore even after all winter)
Old 06-28-2007, 12:24 PM
Well I couldnt find the place yesterday on my lunch and I was about out of gas. I stopped and was filling up with regular diesel when I thought hmmmmm I can go back after work and top off the tank with BIO. Well Its pretty much B50 now. I cant tell a difference in the way it runs but its alot quieter, smells much better and although Ive only started it once on the B50 it seemed to start quicker. Is that possible? GOnna stop on the way home and get e new fuel filter to keep in the truck just in case.
Tags
advantage, advantages, advantaqges, b20, b99, pickups, run, versus, year
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
Forum Jump
  • Ask a Question
    Get answers from community experts
What's your question?
Send
