Go Back   Ford Truck Enthusiasts Forums > Super Duty/Heavy Duty > Excursion - King of SUVs
Register - Join us, its Free! FAQ Members List Timeslips Calendar Mark Forums Read
Is F-150 Still King?
LinkBack Thread Tools
  #1 (permalink)
Old 06-27-2007, 11:54 AM
POLYGUY4 is starting off with a positive reputation.
Frontend Noise When Turning
When i turn to the left i have a clunking noise. I recently replaced the ball joints and sway bar bushings so i know that they are ok. Any ideas?
Sponsored Links
To remove this ad, register today!
  #2 (permalink)
Old 06-27-2007, 12:55 PM
X_Hemi_Guy's Avatar
X_Hemi_Guy has a very good reputation on FTE.X_Hemi_Guy has a very good reputation on FTE.X_Hemi_Guy has a very good reputation on FTE.
Possibly a U-joint?
__________________
2005 Ex V10 4.30's
- Hensley Arrow
- Rear Hellwig
- Prodigy
- RoadMaster Active Rear Suspension
- Bilsteins
- K&N drop in
2007 JayFlight 31BHDS (35' Hitch to Bumper)
  #3 (permalink)
Old 06-27-2007, 01:34 PM
1's Avatar
1 1 is offline
1 is gaining momentum as a positive member of FTE.
Make sure your front hubs arent stuck engaged. Reach up behind the wheel and try to turn the axle/u-joint it should spin freely. If it doesnt your hub is stuck engaged and you probably have a u-joint going out.
  #4 (permalink)
Old 06-27-2007, 01:45 PM
Aatcntrl1 is starting off with a positive reputation.
I have the same exact problem. It seems worst when turning to the left. I heard one member say that when dis-engaging the 4wd system that it's not instant like advertised. The point being when dis-engaging, leave in Neutral for atleast 15 seconds then to drive. I tried this and mine still does it. It worked for some, maybe you.
I get my truck back from the dealer today. If they were able to fix or "duplicate" the problem I will post it.
  #5 (permalink)
Old 07-02-2007, 01:16 AM
GonzoCSU is starting off with a positive reputation.
I just this weekend started hearing a noise in the front end when I turn to the right. It happens at about 3/4 of full turn to the right. It is not a clunking noise it more sounds like something is rubbing, but it is quite loud in the cab. I jacked up the front end and had someone turn the wheel while I layed under it and looked for rubbing. I could not see anything rubbing and the ball joints seem tight. My steering stabilizer is shot but the noise is coming from the drivers side someplace. My hubs are disengaged, spin freely and the U-joints seem tight. I almost wonder if the noise is coming from the steering box or the steering shaft, I could not get an exact location on the sound, just the drivers side.
  #6 (permalink)
Old 07-02-2007, 05:00 PM
chazman is starting off with a positive reputation.
my steering stabilizer is leaking. where do we buy these? and what brand/price/4x4 04 - 6.o diesel
  #7 (permalink)
Old 07-29-2007, 02:18 PM
wenzomatic's Avatar
wenzomatic is starting off with a positive reputation.
Red face More loud sounds
Guys (men and women),
I have an intermitten growling sound from front right side that started when I was making a left turn. I can't see anything wrong and I haven't been using 4WD, could the breaks be draging? I've got about 91k miles and probaly need new breaks anyway, I've also ordered the upgraded rotors. I hope the nose stops or I find something when I've got the truck taken apart to do the roters and breaks. Has anyone been able to fix the noise with something else like bearings?
wenz
  #8 (permalink)
Old 07-31-2007, 06:33 AM
Industrial_dude's Avatar
Industrial_dude is starting off with a positive reputation.
you guys might possibly have bad wheel bearing.
__________________
04 EX 6.0 mods: u name it I prolly got it
07 Ranger 4x4 Tremor pkg
07 Kawasaki ninja ZX6R
07 Eliminator 30ft eagle twin HO's
06 KTM 450SX
04 RMZ250
02 TPD 28ft full of sand toys
  #9 (permalink)
Old 08-01-2007, 02:40 AM
I know it's not my wheel bearings. The dealer just went through and replaced upper and lower ball joints, wheel bearings and the entire fan damily. I guess they didn't road test it because it still makes the same exact noise. Drives nice but still the same noise. My neighbor said his 96 F250 had that problem and it was his body mount bushing. It had "gone away". I checked the ones I could get to without tearing everything apart but no lock. I tell you what though it sure does feel like it could be it. I can really feel the popping through the body.
__________________
04 limited, Donahue lift, Robbie Gordon wheels, 35's, FOX shocks, AFE CAI, Banks exhaust, SCT Tuner (innovative diesel) ARP head studs, Kenwood Nav/DVD.
2007 Stellar 28ft toyhauler
2005 Monterey 228
1999 Corvette, Bassani exhaust, headers, FAST intake, Weld EVO wheels a custom tune
  #10 (permalink)
Old 08-01-2007, 11:49 PM
Jeepincj7's Avatar
Jeepincj7 is starting off with a positive reputation.
Tires rubbing the springs? See if you your spring have a shiny spot from the tires rubbing slightly.
__________________
Scotty
FOR SALE:
00' X, V10, 4wd, Ltd, 4.30s, 7" Donahoe Edge lift, 37" Toyo M/Ts on 17x9 Mazzi Hulks, Derale deep pan, A/T temp Gauge. $14,500 OBO
PICS
www.AddictedOffroad.com
  #11 (permalink)
Old 08-02-2007, 03:23 PM
I got down there last night with some wrenches just looking for anything that may be going wrong. I found the U bolts to kinda loose. Now they weren't real loose but enough under torque that things could be moving around. So I did my best with a wrench to snug them up. Now I noticed today that it's not nearly as bad. I didn't hit it with a air gun because it was late and my compressor is pretty loud. So I'll give it a shot at the end of business today. Boy kinda scary to think those things are kinda loose. THey must be under some extreme stress. I bet they haven't been checked since my lift kit was installed. ANyways I'll keep you guys posted. Might be a piece of mind for everyone to check those especially if they have been tampered with such as a lift kit. I'd hate to be coming down Cuesta grade and one of those bolts let loose.
__________________
2005 Monterey 228
  #12 (permalink)
Old 08-15-2007, 07:39 PM
wenzomatic's Avatar
Red face Got it fixed
wenz
Changed the rotors (front friction upgrades) and break pads found the right rear pads worn out and rubbing on the rotor. That was the noise. Funny how it only was intermittent...
wenz
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
vB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Powered by: vBulletin | Copyright ©2000 - 2008, Jelsoft Enterprises Ltd.
Ford-Trucks.com and Internet Brands, Inc. are not affiliated with the Ford Motor Company.
