A/C switches to defrost
I have a 99 f-250 CC v-10, and when my a/c is on, the fan will blow out of the vents in the dash and switch to the defrost vents when you really get on the throttle, and when you let off the throttle and just drive normal in comes back to the vents in the dash. Any ideas would really help.
Thanks
Tom
Thanks
Tom
Originally Posted by Tjdb2000
I'll check it out. Correct me if I'm wrong, if there is a vaccum leak anywhere in the system, could it act this way?
The correct answer is yes and no. If there is a one-way check valve in the heater control vacuum line and the leak is before the valve (engine side) then no, it will not have an effect on the air distribution control. However, if there isn't a one-way check valve, then yes, any leak anywhere in the vacuum system can cause the air to default to the defrost under load, which causes a natural momentary loss of vacuum.
If there is a vacuum leak on the engine side of any vacuum system, then it might also light the MIL and cause a lean mixture trouble code.
Unless you have a reason to think that there is a leak somewhere other than the HVAC system, I would think that you would want to start looking in the heater air distribution system for the leak or loss of vacuum. Find the vacuum cannister, or the one-way check valve, and more than likely you will find the leak/loss.
What the cannister does is act as a buffer for the momentary losses of vacuum which occur normally under certain driving conditions, such as stepping on the gas, or under power, such as going up a long, steep grade.
Hope that helps some and good luck. Please post what you discovered.
Dan Harriman 84 F150
Orange, Texas
pickupman2002
09-24-2012 02:37 PM
totalblue
1997-2006 Expedition & Navigator
10-03-2011 06:35 AM
RollTideRoll
1999 to 2016 Super Duty
05-22-2011 03:33 PM
