Anybody use the ball joint kit from.....
Old 06-27-2007, 03:49 AM
HawaiianPSD's Avatar
HawaiianPSD
HawaiianPSD is offline
Powerstrokeshop?
http://catalog.powerstrokeshop.com/partlocator/index.cfm?action=MorePartInfo&PartID=356094&siteid =214083&catalogid=3660
I'm in need of new balljoints (mines are clunking already). Is this kit all I need to get them replaced or, is there anything else you guys recommend I pick up? Appreciate any help, thanks guys!!!
Old 06-27-2007, 05:38 AM
Benny2002's Avatar
Benny2002
Benny2002 is offline
Ya Kris Strokin_it 7.3 used it and im going to buy it this weekend
Old 06-27-2007, 06:53 AM
PowerstrokeJunkie's Avatar
PowerstrokeJunkie
PowerstrokeJunkie is offline
Yep i bought it and it's in my truck. Have a little issue though, the top passenger ball joint grease fitting snapped off flush during my first run down the drag strip. Tried getting it out in the truck but i guess i'll need to pull the knuckle. You'll need a ball joint remover/installer tool, and it will be alot easier to take the axleshafts to a local machine shop to get them to press the seals on. I messed with them for 2 hours with my 25or 50ton and i just couldnt get them aligned correctly.
Old 06-27-2007, 09:46 AM
RedDragon's Avatar
RedDragon
RedDragon is offline
I put the kit on my truck. It has all the parts you should need. You'll have to get the seals and joints pressed on if you don't have the tools to do it.
Old 06-27-2007, 09:28 PM
HawaiianPSD
Right on, thanks for the info guys, appreciate it!
Scottys-350
05-01-2008 10:35 PM
jnb
03-09-2008 07:56 PM
PETE'S_6.0PSD
01-15-2008 06:18 AM
Jay-re
05-16-2007 09:13 AM
Quick Reply: Anybody use the ball joint kit from.....
