fuel filter wrench size
06-26-2007, 08:06 AM
on
hey guys i wanted to change my fuel filters today and need the size for the hfcm cap is it 31,32,33 mm i cant seem to get the tech folder to open the fuel filter changing procedure area, thanks for any help.
06-26-2007, 08:44 AM
on
HFCM fuel filter takes a 36mm or a 1 3/8" socket. I use a 36mm socket.
Hope this helps.
Daryl
2004 F250 4x4 CC KR
06-26-2007, 09:05 AM
yup--36mm and I got mine at sears for like 6 bucks--cheap.
06-26-2007, 10:01 AM
on
Or you can get the nifty close clearance, aluminum, 3/8" drive socket from Lisle Tool specifically designed for filter changes on 6.0 Powerstrokegs.
06-26-2007, 10:15 AM
on
the fuel filter cap is the same size as the oil filter cap?
06-26-2007, 10:27 AM
I don't think they are exactly the same, but they are close enough that everyone uses the same socket. Somebody correct me if I'm wrong.
While we are on the subject though, what is the correct torque value for the filter caps?
06-26-2007, 10:43 AM
on
Quote:
The Lisle socket is advertised as fitting both sizes.
06-26-2007, 11:04 AM
on
oil filter cap= 18 lbs./ft
frame mounted fuel filter= 19 lbs./ft
secondary fuel filter (under hood)= 8 lbs./ft
06-26-2007, 11:24 AM
Just screw until seated all the way. I have heard many state that the plastic caps will hit their "torque value" before they are seated all the way.
Just screw down and tighten until flush and it will not turn any more. No need to use a "breaker bar" or "lean into it"... just make it tight and visually look to see that it seated all the way down.
06-26-2007, 01:44 PM
Yes--on my 04 anyway.
06-26-2007, 01:45 PM
Quote:
Same here. $6.80 at Sears...
brother steve
6.7L Power Stroke Diesel
15
10-29-2015 02:24 PM
Jonesy0027
12-11-2013 10:47 AM
macguy
11-30-2012 07:01 AM
fordtruck661
10-22-2011 08:44 PM
Blind45
09-09-2008 12:29 PM
06 ,
2003 ,
2006 ,
60 ,
diesel ,
duty ,
f250 ,
filter ,
ford ,
fuel ,
size ,
sizes ,
super ,
tool ,
wrench
