Go Back   Ford Truck Enthusiasts Forums > Diesel > Competition
Sign in using an external account
Register Forgot Password?
Register - Join us, its Free! Albums FAQ Members Tech Guides Search Today's Posts Mark Forums Read VendorsUsed CarsGarage
Welcome to Ford Truck Enthusiasts Forums
Competition Diesel racing, sleds, dynos, power tuning and max performance.
  #1 (permalink)
Old 06-25-2007, 11:47 PM
Dustin_86 Dustin_86 is offline
Garage is empty, add now
Dustin_86 is starting off with a positive reputation.
Unhappy Pulls- very disappointed
My buddy pulled his 91 two days ago. It is a F250,2wd, 4.1, ZF, 7.3. He "turned up" the screw on the pump. He hooked to the sled, and had no traction problems. He let the clutch out at 1500rpm in 1st gear and he got itmoving about 20' and about 1800rpm then it quicklt brought the 7.3 down to 1,000rpm-floored before he hit the clutch. Seems kinds weakto me it should ATLEAST spin the tires trying to move the sled. Are the IDI 7.3's that weak or did turning up the fuel screw "screw" him.
He Still thinks my 78 F250, NP 435 ,300 I6 would make atleast 100' before traction problems, but after seening that i'm not so sure.My truck should spin the tires in granny gear tied to a sled right?-maybe??
Thanks,
Dustin
__________________
1978 F250 2wd RC,LWB,300 I6
NP 435 3.73 trak loc HD 460 V8 coil springs
At least the Chow lets you know it is unstable, she just left cheated and called back crying with her appologies.
Reasons To get a dog over a women
  #2 (permalink)
Old 06-26-2007, 09:40 AM
wizzard351's Avatar
wizzard351 wizzard351 is offline
wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.wizzard351 has a great reputation on FTE.
when me and my brother used to pull we didnt want to spinn rite from the git go.on a good tight track(clay)the only time you should spin is when the sled "gets ya".we found out that granny gear was usless cuzz you cant get enuff speed out of it use 2nd low range and buzz the snot outa it
__________________
71 F250 300 4sp w/pto 4x4
92 F150 300 w 5sp 4x4
2000 F250 4x4 super duty 7.3 power stroke
01 ranger 4.0 4x4 (wifes)
  #3 (permalink)
Old 06-26-2007, 07:49 PM
we found out that the 7.3 IDI will NOT even break the tires loose with 4.1's(2wd) and in low (zf5)
Do you think my 78 can?
__________________
  #4 (permalink)
Old 07-12-2007, 01:02 PM
Todd525's Avatar
Todd525 Todd525 is offline
Todd525 is starting off with a positive reputation.
that is one tired id then. I had one before my current strokers and it would spin em right over WITHOUT much grunt at all.........
__________________
96 F350 CC Dually PSD. Tuner, straight pipe, 6637 filter, ribbed diff cover, 12.7k mod, 28k tranny cooler, 3 plate TC, autometer boost, trans, and pyro. Used 4 Car Haulers, 5th wheels, goosenecks, Fat Chicks.
01 F250 CC 4x4 PSD. SOLD.....Kinda missed already, and its Day 1.
http://i213.photobucket.com/albums/c...525/Loaded.jpg
  #5 (permalink)
Old 07-12-2007, 09:27 PM
Dean88's Avatar
Dean88 Dean88 is offline
Dean88 has a good reputation on FTE.Dean88 has a good reputation on FTE.
Huh, can't get a 7.3 IDI to break the tires? My buddy's 1992 F350 dually will whitesmoke the tires if you pop the clutch right, and his motor is plum wore out.
__________________
1999 F250 7.3 ZF6 4x4 3.73's 200k miles
1997 F250 7.3 ZF5 2wd 4.10 430K miles
Dr. Ron Paul 2012!!
  #6 (permalink)
Old 07-15-2007, 05:49 PM
nope she wouldn't break them loose on clay, this has my 300/np worried
__________________
  #7 (permalink)
Old 07-18-2007, 04:28 PM
pioneer_plowboy pioneer_plowboy is offline
pioneer_plowboy is starting off with a positive reputation.
Yours is 4wd, right? So put in 4-lo, and pull in 2nd. If you take off, and it is lugging, try to stop before the 75 foot mark, and you can start over. Use first then. But most of the guys around here pull like that with no problems.
  #8 (permalink)
Old 07-20-2007, 07:38 PM
no its 2wd, but I've seen 2wd's pull 250+ ft so it is more of atorque/gear question
__________________
  #9 (permalink)
Old 08-12-2007, 12:19 AM
SANDDEMON08's Avatar
SANDDEMON08 SANDDEMON08 is offline
SANDDEMON08 has a good reputation on FTE.SANDDEMON08 has a good reputation on FTE.SANDDEMON08 has a good reputation on FTE.
Quote:
have you played with the timming at all, or checked it?
__________________
Got beer ? 611 HP 1205 TQ
08 F350 CC FX4, 6.4 PSD,PMF 4.5" LIFT WITH TRACTION BARS,3.73 REAR, NAV ,DASH DAQ, VOLANT INTAKE,SPEARCO INTERCOOLER,STAGE III WATER/METH INJ,67 GAL TITAN TANK,COMPLETE EGR DELETE,ARP HEAD STUDS,71MM LP BILLET TURBO,FS-2500 BYPASS FILTER, AIR DOG II FUEL PUMP,CUSTOM CCV MOD,MAG-HYTEC TRANS PAN AND DIFF COVER, CUSTOM HD TRANS COOLER, SEIC MOD,AMP STEPS
  #10 (permalink)
Old 08-15-2007, 03:11 PM
crazymike's Avatar
crazymike crazymike is offline
crazymike is starting off with a positive reputation.
im thinking that truck needs some engine work i have a 91 myself and i can get it to spin all 4 if im tied to something i cant move -not that theres much i can't move.
it can spin the rears just about anytime i want it to unless im above second.
iv got a rebuilt e40d and a tall rearend.
i hope you get that thing pulling better
__________________
91 f-250 4x4 280,000+ on the clock. k&n intake, rebuilt strengthened e4od,with 94 style tcu, all sensors new, warn hubs
  #11 (permalink)
Old 08-16-2007, 04:24 PM
blake 7.3L's Avatar
blake 7.3L blake 7.3L is offline
blake 7.3L is starting off with a positive reputation.
I hope you have better luck next time. Me and and a good friend of mine both have 7.3L idi's w/ turbos and have never pulled under 210 in the single turbo class. But after the turbo my first clutch went fast.
__________________
1997 F350 CREWCAB 4x4 7.3L Powerstroke, 4.10's, Built BTS Auto, 6 pos. chip with Cale's Tunes, 4" exhaust, Z-Series Gauges, 140V IDM, Tymar Intake, HPX, Adrinaline HPOP, 7.3L intercooler, RDS stage 2's (180cc), Modded H2E, and 3" SD intakes
Coming Soon: Locker and Elec. Fuel
  #12 (permalink)
Old 08-20-2007, 04:05 PM
matt16875 matt16875 is offline
matt16875 is starting off with a positive reputation.
Pull the 300. There are a couple of guys around here that pull 300's and they are very impressive for a 6 cylinder. I have never seen any 300 come in last unless they were pullin in the big block class. The one guy is running an 89 f-150 300 with 33" tires, posi rear and enough weight to make the 6500 and 7800 lb classes. I have never seen his tires quit spinning in the 5 years that I have been watching him pull. The motor is stock. Actually he bought the truck for $200 and just started pulling it aside from installing a mini-spool in the rear. He beats V-8's all the time. Now he has only won 1 time that I know of but everybody loves it when he comes to the line because of the big ole 6.
Oh yeah, his truck is 4x4 and a manual tranny also.
Tags
2wd, f250, pulls
Search this Thread:
Advanced Search
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is On
Trackbacks are On
Pingbacks are On
Refbacks are On
Forum Jump
Powered by vBulletin® Version 3.7.5
Copyright ©2000 - 2013, Jelsoft Enterprises Ltd.
SEO by vBSEO 3.5.2 ©2010, Crawlability, Inc.
vbulletin Admin Backup
